Topic: Two-Cylinder Bolt On (Read 7953 times) previous topic - next topic
Quote from: CoogarXR;351519
Or go even further and plumb your freon lines through your intake coolant passages and have a permanent cold air intake!
:headbang:
I didn't see anybody address the exhaust...with the two-cylinder bolt on it's always a good idea to get heavy duty ler bearings as they are stressed pretty bad.  I like to wipe them down with halogen fluid when installing...then I top off my headlights as necessary.  Good luck!
I am sure he replaced the ler bearings when he added the dual Folgers Can exhaust mod...
CoogarXR : 1985 Cougar XR-7
This mod is so BA i had to come out of hiding lol. I need to do this to my Crown Vic, V10.5 cop car FTW:mullet:
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
No doubt. Might as well recirculate the exhaust back into the motor to, free supercharging FTW!!!11
85 Tbird 5.0
78 F150 351w
i actually took the time to read this? hood gasket?:bowdown:
Hey, this is some good engine tech. Why move it to the non-technical lounge? :(
I thought it was helpful. I was considering doing it to my next v6 car....
Reply #39
Quote from: sarjxxx;352851
:bs::bs:
Amazingly this is the only post I could use this smiley on
Reply #40
dont forgot, when adding the weight of a supercharger, you must re adjust the johnson rods during alignment procedures, otherwise, the wheel might be off.
also, take your smog pump, feed it into the air intake, and put a smaller pulley onit, gotta be good for a pound of boost. easy.
add the appropriate stickers, and your on your way.
Reply #41
I actually did something similar to that:rollin:
Reply #42
Quote from: sarjxxx;352867
The stickers or the johnson rods?
Reply #43
or a smog pump supercharger...
Reply #44
after reading this i couldn't help but try all those mods. now the car runs better than ever! So i focused on interior. the old magnavox vcr display (with some thought) will fit right in the dash! a crow bar and double stick tape is all you'll need for the install. I was also able to build a nifty tatoo gun with what was left of the vcr!
