Topic: Two-Cylinder Bolt On (Read 7984 times) previous topic - next topic
Quote from: Scott D;351157
What about the rear cylinders that aren't covered? Should I use the other half of the cookie sheet I didn't use in the oil pan extension to cover the two cylinders? Also, what if I just cut holes in the hood for the cylinder heads? You know, holes a la 87/88 Turbo Coupe ;)
this is where the dryer vent tube comes in...
I hope your not using a fiberglass hood. I've heard they don't seal very well and you might end up with a blown hood gasket.
was just reading up on the pie plate flywheel mod, seems its good for about 100 extra horses.
Now there's an idea! Any thoughts on which brand is the best? I know Libby's is a classic but I've heard good things lately about Sara Lee.....
lmfao. Blown hood gasket....
-'88 Tbird 3.8
-2012 Altima 2.5 BASE.
Future: Budget 5.0 300 HP.
Quote from: sarjxxx;351178
Well, I hear the stock hoods aren't much better when we're talking the original 3.8L Esshag block
Don't forget to add the hamster wheel. You need the extra power to spin those two extra cylinders.
Quote from: thunderjet302;351298
But, if I add that, I'll have to rebalance the crank shaft.
I lost it at the "blown hood gasket" hahahaha.....I got to pee...
1971 Camaro Blown 640ci
1988 T-Top Mustang
1980 Mustang coupe
1988 Thunderbird TurboCoupe
Previous Thunderbirds:
1988 Sport
Quote from: Scott D;351244
that's why you have to be extra careful;)
Hey listen, while your at it, you might want to consider adding an electric supercharger. 1 PSI of boost is the perfect compliment to a two-cylinder bolt on. At least, that's what I've read.
Btw, this is going to take you well past the 1 Gal of American Fury mark. Where are you going to end up now? I'm guessing 1.6 Gal, Commercial Size.
You don't need to buy the electric supercharger for the extra pound of boost just use a good dryer tube and mold it to your fan box in the dash and blamo extra boost
87 TC
Quote from: bigbada1;351393
I already have the dryer tube running from under the front bumper, into an old hair dryer my wife had (well, not really old, it's the good one she uses all the time) that feeds the intake. One of the absolute positives is it's got a HIGH and LOW setting ...two stage turbo :headbang:
You hear that, gumby, you're going down :headbang:
You could also take your AC evaporator from out of the dash and mount it inline with your dryer tube under the hood in front of the hair dryer for an intercooled CAI....
Quote from: sarjxxx;351512
Or go even further and plumb your freon lines through your intake coolant passages and have a permanent cold air intake!
CoogarXR : 1985 Cougar XR-7
