Topic: Headlight Adjustment (Read 2394 times) previous topic - next topic
Does anyone know how to adjust the headlights on an 87-88 Thunderbird/Cougar? I'm going to try adjusting them again. I've polished the  out of them, repainted the inside reflective material, and they looked pretty good. But in all honestly if I turn my turn signal on, the one on the corners of the header panel shine further than my headlights. I kid you not. Now I don't have a alignment board, and I've asked two shops in town, and they don't either. So I'm not sure I can get them perfect, but at this pint anything would be an improvement.
I searched, but after twenty minutes, I figured It'd just ask. I couldn't
anyone? lol I think they are pointed down to the ground too much.
Are you asking how to adjust them, or how to aim them. This is what I use to adjust them. Kind of a pain to get to the screws, but this works well: http://cgi.ebay.com/ebaymotors/Lisle-14540-Headlight-Adjusting-Ratchet-Ford-/330516719323?pt=Motors_Automotive_Tools&hash=item4cf454e6db To aim them, I just park on level ground in front of a wall where I can see the headlight pattern.
2017 Subaru Outback
2007 Lincoln MKZ
1990 Ford F250 / Banks turbo diesel
Yeah, if you have a wall and level ground, you can aim them yourself.
In general, pull up close to the wall with the lights on, and mark the locations of the lights.  There will be a definite demarcation line where the upper part of the beam is cut off. This will be your vertical mark.  Also mark the horizontal center of that as well.
Back the car up about 30' (I think) and see where the beams are in relation to your marks.  IIRC, you want the marks at 30' to be about 1/2" below the the vertical marks and about 1/2" to the right of the horizontal marks.
This means that the beams are aimed slightly down and to the right.
That is what I was looking for. Thank you sir.
Thank you again.
