cruise control not working May 14, 2005, 01:18:53 AM I just bought an 88 XR7, it has 58,000 mile on it and is in great shape, but... the cruise control doesnt work. Anybody else run into this? I just got it home tonight so I havent looked into it yet, (maybe just the fuse?) I doubt it, Im not that lucky. Any help would be great, also I'm in need of an argent cougar center cap for the Mustang turbine type wheel. Thanks in advance. Dan Quote Selected
Re: cruise control not working Reply #1 – May 14, 2005, 01:51:05 AM I've seen two causes for this. the most common is when the steering wheel contact rings disintigrate and you lose power to your wheel mounted controls. If this is the case, good luck searching for a replacement.(try the want ads on this board) The other happened to my '87. The metal clip on the cruise control unit (located in the left wheelwell behind the tire, under the splash-shield) broke. This is the clip that pulls on the secondary throttle cable that works your cruise. I had to get a clip from a donor car. :canada: Quote Selected
Re: cruise control not working Reply #2 – May 14, 2005, 04:26:42 AM mine stopped working cuz the computer went out. it also make my brake lights not work. I unplugged it so my brake lights would work, ever replace the computer tho (got an aftermarket wheel so even if the computer was replaced I wouldnt have cc) Quote Selected
Re: cruise control not working Reply #3 – May 14, 2005, 11:53:07 AM I'm pretty sure that Grant makes Cruise control switches that mount to some of their wheels and work with the ford system. I read about it in either Hotrod or Car Craft. Here it is. Just type "cruise control" into their search engine. :canada: Quote Selected
Re: cruise control not working Reply #4 – May 14, 2005, 12:08:13 PM you might wanna have a looksee at this.. Quote Selected
Re: cruise control not working Reply #5 – May 14, 2005, 10:40:52 PM Might just be the switches on the wheel not making good contact. Every couple or three years mine quits or goes intermittent, so I just whack the buttons real hard with my knuckle a few times, & they seem to get better for a while. Quote Selected
Re: cruise control not working Reply #6 – May 14, 2005, 11:31:10 PM Mine didn't work because the clip on the throttle body was broken. Fixed that and it works now. But like both my old fords, The SE and an 87 ranger the coast feature doesn't work. You press it and instead of droping one mile an hour it gains one mile an hour. I'm guessing the brain is going out on both of them. Quote Selected
Re: cruise control not working Reply #7 – May 15, 2005, 01:59:09 PM Cruise control slip ring testother associated possible faults are the horn relay or the fusetest the slip rings..............jack up the front end of your car (both wheels)unplug the eec from pass kick panel (this allows the entire harness to be checked)set meter to ohmsprob the harness for pins ..50- feeder to all contacts normally open39- ground side of all contacts normally openrotate the steering wheel while you actuate the following switches for the below ohm value. (+- 5%)off - 0 to 4 ohmsResume-2200 ohmsAccel -680 ohmsCoast -120 ohmsif values fluxuate while steering is rotated, relub contacts with conductive compound, observe wear marks and bend or tweek them as needed then retest.***At the stearing column check only***If you wish to just check the slip rings themselves,, locate connector C113 behind stearing column.find a connector with the following colorslight blue/black- cruise feed , (same as eec pin 50)black- cruise ground (same as eec pin 39)*****the 1987 evtm says the above wire is black but my 1987 suppliment manualcalls the above wire to be orange.yellow/light green- horninsert your ohm meter leads into the the light blue/black and the black wirecheck for the same resistance values. if values are much better or greatly improved,your wiring harness to the eec has damage or above normal resistance. Quote Selected
