Topic: Pulling the AOD (Read 2920 times) previous topic - next topic
Pulling the AOD
Pulling it out tomorrow and getting a guy to rebuild it for me. I thought of a Lentech AOD but this guy is ging to put extra clutches in it and better lube passages and set it up better than a Lentech. Cheaper too. So I cant wait till it is done then I can go to dyno and set up my 351w to idle and not eat fuel.
:burnout:
Pulling the AOD
Oh and I am installing my TC rear diff with 3:73 gears and the prop valve with the brake lines so as to make the installation easy. I hope.
:burnout:
AOD pictures?
I am fabricating a dual exhaust for my stock (semi-H.O.) 5.0 with AOD. The RH half of a BBK O/R H-pipe fits perfectly except it is 2 1/2" and I will be using 2" with my cast iron manifolds. I am contemplating how to best route the LH pipe thru the two-hump crossmember at the transmission mount. I suspect the shifter linkage is different on cars that were built with duals (Mustangs & maybe some Cougars?) but the factory stuck the shifter cable right where my pipe needs to run. Do you have a photo of the transmission cable and arm on your car where the left pipe passes by? I sure would like a peek.
Pulling the AOD
86caprirs what converter are you going to run? I'm running a 2800 rpm stall PI Stallion non-lockup converter and I love it. Instant power and instant go when you push the pedal :burnout:.
Pulling the AOD
i have shorty headers and a h pipe on my 87 5.0 tbird and i didnt have issues. if you can just let it hang lower and maybe indent the pipe a bit around the linkage or put header wrap on it if its close to the cable and your worried about it melting i dont have anything on mine
Pulling the AOD
The guy building it says a 3000 stall for the street. I think it is a non locking too.
I am actually using a 95 Mustang x pipe built by unknown. Fits great and it is in 3 pieces. I have a double hump crossmember from factory. I did bent the  bracket for the shifter. But I may cut and weld it to fit better since I have the trans out.
:burnout:
Pulling the AOD
No update yet. The tranny guy has been super busy.
:burnout:
Pulling the AOD
So do the 88 T-bird/cougar have lockup converters. My gas milage sucks now after replacing my tranny. I wonder if my converter is non-lockup. I went from 18-20 mpg to 13 mpg. I didnt notice if it started going down right after the tranny swap. I got the tranny from a friend, it was rebuilt and had a new converter so I used it.
Pulling the AOD
I'm pretty sure we have lock up converters..............
Pulling the AOD
I'll reseach more. That sucks. Now I might need a new converter too. It least I'll have the motor out.
Pulling the AOD
I am not sure what we have for converters. I never asked.
:burnout:
Pulling the AOD
thats exactly what mine did.  mine is a jasper tranny
