Topic: 5.0 timing cover (Read 823 times) previous topic - next topic
5.0 timing cover
Well, went to replace my water pump today from the fansplosion last week, and found a fragged timing cover as well. O joy. Anyone have a spare around?
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
5.0 timing cover
If the ones on the mn12 5.0's are the same I can pull one for you but I don't know if they are and I don't know how to check...
5.0 timing cover
Quote from: sarjxxx;350146
the only difference would be the waterpump and from what I remember the different one was on the F-150 302
5.0 timing cover
I have a coupla extras...tell me what one is worth to you, and i'll get a shipping quote via USPS....fair enough? lol
5.0 timing cover
Well, i found one locally today. Thanks guys.
Chris
87 Thunderbird 5.0
TC 3.73 L/S rear
