Topic: Injectors & ECU (Read 2650 times) previous topic - next topic
Injectors & ECU
The injectors in my 92 mustang engine are the stock 19lb/hr
Researched and found the injectors from a stock 87 thunderbird 5.0 are 14lb/hr (correct me if I'm wrong)
So my question is, would using an 87 thunderbird ECU have issues with my 19lb/hr injectors? Buying an 87 Thunderbird wiring harness for my engine swap... Should I not buy an 87 ECU with it, or can I simply plug in and use 92 ECU from the mustang?
Thanks!
Jeff
302 H.O Swapped.. Bolt ons.. Tremec 3550.. 4.10's.. 18's..
Injectors & ECU
i think everyone here will agree with this statement.. STANG HARNESS and ECU
Injectors & ECU
Mustang ECU if you are using mass air
Injectors & ECU
Right on.
The stang harness won't plug & play though...? I don't really want to re-pin everything.. Tell me why I should use stang harness?
Injectors & ECU
Use a 5.0 Thunderbird Harness,add the Mass Air to it,install a Mustang ECU and there you go. Stang harnesses,if I remember right,are not a direct swap into the Birds. They are different. It took a short amount of time to do the Mass Air swap. 6 wires..add two,move two,tap in to two. Done.
Injectors & ECU
That's what I figured!
Found a tbird harness with mass air already added. That harness is ALLLL MINE!
You guys rock.
Injectors & ECU
So 19lb mustang/explorer injectors are not plug and play with a stock 88 thunderbird computer?
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
Injectors & ECU
Quote from: GDawg148;450293
No they are not. You need a HO computer (and HO cam) to run 19lb injectors.
Injectors & ECU
Thank you! I ran into this problem.  Now I know.
'88 Thunderbird LX
