Topic: "Heat Soaked Starter" Fixes (Read 5645 times) previous topic - next topic
So today was a little slow at work and I started thinking. My starter get heat soaked, after driving on 50 degree plus day, is i drive a couple of miles to the store, shut the car off and try to start it a little while later, it doesn't have the umphf to crank the engine over. But if i put a booster pack on, it starts right up/
Now I've replaced the battery and the battery is positively good, it's been voltage checked and everything.
I did a good search and came up with this thread:
http://forums.vwvortex.com/showthread.php?2593146
Has anyone done this to a foxtbird, cougar, or mustang? It got me thinking, i have a stock configuration on my car, no engine mods, no exhaust upgrades, nothing. I know about the high torque mini starters, but i'm too cheap to spend $150 ish on a starter that may or may not solve the problem. Not that the problem is too too bad, after an hour, the car is guaranteed to start, but just the same. Has anyone done a mod similar to the thread above?
I also found: http://www.themustangshop.ca/product/300189/300693/. Has anyone else here used a similar one? What brand did you use, how much was it, and did it work?
I had that problem in the summer in the past on hot days and the mini-starter fixed it.  I believe you can do a mini for a lot less than $150.
Hit the salvage yards and look around. I happened to find a new mini starter on an Explorer with a 5.0 a couple of years ago and grabbed it,the intake and GT40 heads for $75.00. I kept the starter and sold the rest.
Bob, do you have any engine upgrades, exhaust modifications, etc? I may be able to do it for less than $150, I called one parts store and asked about them, it was like $139.99 or $ 134.99 with a core. Just wondering if anyone else has this problem. I can't understand it. If I had headers I could see it, chevy guys have that problem all the time, I just can't see how a stock setup would. Ford didn't put insulators on these cars, so it couldn't have been a big problem back in the day, or they would have. I've checked the grounds time and time again. I even connected a negative booster cable to the negative terminal on the battery and then to the block(to ground it), to check and see if the grounding wires weren't functioning, and the starter still did nothing.
Vinnie: I can't hit the yards, everything is under a foot of snow, lol.
How old is your starter?
Quote from: vinnietbird;347416
This one is less than a year old. I have gone through at least 3 of them in the 5 ish years I've had the car. I bought a cheap carquest one first, lasted about 6 months and it was dead. The second one was the medium grade one which was dead out of the box. They replaced it, put the next one in it last just over a week it ped out in the work parking lot.  So they replaced it with whatever they had in stock, which was a premium one with a year warranty. It ped out 12 months and 2 days(it had a 12 month warranty), I just looked up the receipt. Now this one was put in and it gets heat soaked. Otherwise its works fine, I'm just worried one day it'll just  out and leave me stranded. I'm thinking maybe this one should be rebuilt, I might call and see about a warranty on them.
Yes it is cheaper, however what about a warranty? This thing could be made in china and be worse than whats in the car. I dunno. Buying stuff like that on ebay scares me.
*Edit*: It says they are guaranteed for a year, I dunno. It's something to think about...
Your starter is junk. I have done the auto store "upgrades" several times, and none of them lasted me for any real point in time. When we had several fords all running the same starter, we bought a lifetime warrenty. In about 6 months we replaced 10 starters and we asked to never come back. Last one I found laying in the gravel at the junkyard for $5. It was full of water and covered in grease. I set it on the shelf thinking I would try to rebuild it myself and it ended up in the back of my car. After my starter went out, I remembered I still had it in the trunk, and swapped it out in the 7-11 parking lot. lasted about 30k so far.
My friend bought the Ebay starter(about $50.00) for his 5.0 equipped '67 Stang over a year ago and it's still doing it's job as advertised. I was thinking about getting one when the time comes for a new one.
So would you guys recommend buying one if the high torque ones, or having the one in the car rebuilt by a very reputable local place?
Quote from: jpc647;347410
Yeah it was a 306 with eddy heads/tfs1 cam/cobra intake, shorty headers and offroad hpipe.  PAperformance has the mini-starters for $135 thats where I got mine good quality and lifetime "new" replacement.
auto part stores starters are all , they're build very VERY poorly with trashy brushes and what-not
Quote from: turbo_88_XR7;347576
Should I expect this one on ebay to be any better?
Quote from: jpc647;347621
The ebay one is new not rebuilt , but its like anything 50/50 odds
That ebay one is a correct replacement for mine, for an 87 Thunderbird 5.0, right? I only asked because I cross referenced the part number it list as an upgrade for and it states 82-90mustang, blah blah blah, but does the HO had anything different? Will this be "too powerful" for a stock thunderbird 5.0 motor?
