Topic: timing gears (Read 1864 times) previous topic - next topic
timing gears
anybody got good video of em with the car running? i know i saw R.J.'s (1wildbird) on youtube, im thinking of getting em... i like the blower sound, and im wondering if it will go well with the sound of the KB blower :D but i cant find any good sound clips, let alone a KB with the gears...
timing gears
I got a set in my 351w but its not running yet!!!! Sorry!!!  No sound for ya!!  They do sound good. I got the quieter version so it doesnt get to annoying!!
BUUUUUUUUUUUUZZZZZZZZZZZZZ!!!!
1999 Trailblazer(wifes rig)
timing gears
My brother had a set once ..I hated it and so did he , it sounded like a cat was stuck in the fan
 all a matter of taste though
timing gears
There also not good for the camshaft and valve train.
timing gears
Somebody enlighten me.... what are they good for?
FOXLESS!!
1994 Lincoln Mark VIII
timing gears
Quote from: 20thanniver-ls;346374
No chain to stretch or break , maintains timing better
So the manufacturers claim
timing gears
Ah, I see. Probably best for Hi-performance motors?
FOXLESS!!
timing gears
FOXLESS!!
timing gears
They might last longer, but they do not do timing any better. They transmit alot of harmonics and vibration into the drivetrain that can actually make it hard to keep timing at higher RPM's. For the $80 you would pay on top of a normal double roller timing chain, I would just stick with that.
My stock single roller lasted 170k or so. I have no reason to doubt a double would last as long, or longer then the stock one.
Here is a thread from SBFtech. on the subject.
http://sbftech.com/index.php/topic,18613.45.html
Long story short, it will take MORE power. It costs more, and there is no benefit.
Here is another quote for you.
I used a Dynagear drive for some time. Engine ran for about 3 years with very little maintenance at the strip, but developed a mysterious bog off the line. Changed everything, went back to what I started with, but changed to a timing chain instead of gear drive. Not only did it run fine again, but it also picked up .3 second! who would've figured? Seriously, it was very easy to install, just had to grind a casting off the inside of the timing cover. It was easy with a Dremel tool. That's all that was required. Man, that thing was noisy!
http://www.fordmuscleforums.com/all-ford-techboard/415622-289-302-gear-drive.html
timing gears
hmmm interesting, i always liked the sound of a roots style blower, thought i'd make the KB im getting louder by useing the gears, but maybe ill just use the chain. i keep getting more and more bad things about the gears.
timing gears
the harmonics tend to weaken the idler gears after a while.. i have a pete jackson set where 1 of the teeth actually cracked and chipped.. but i've used others and ran more miles with no issues.. but the harmonics really throw things off a bit
timing gears
I ran a B&M gear drive in my Z28 for years with no prob on the street and track.
I would not run one anymore just for noise they make.  But each to there own.
timing gears
not to mention, after a few thousand miles, they lose their 'blower' sound and just gets down right annoying
