Topic: 87-88 T-bird H-pipe (Read 7904 times) previous topic - next topic
87-88 T-bird H-pipe
Has anyone seen this on summit? I wonder if it bolts up to the t-bird/cougar manifolds or if its a mustang H-pipe that fit mustang headers. If you click on the application it only shows that it only fits 87-88 T-bird. Did the T-birds ever come with an H-pipe?
http://www.summitracing.com/parts/CTO-4179/
87-88 T-bird H-pipe
i believe i'm correct when i say no, they didn't come with them.. don't even think MN-12 cars had h-pipes.. but if summit lists that they're made for the bird specifically, than i would assume they will fit
now what i don't understand is.. why doesn't it list cougar? i know 87-88 cougar drivetrane is identical and so is the underbody.. what gives?
87-88 T-bird H-pipe
My money says Mustang H.O,and Mark VII H.O. They may say T-Birds and Cougars,but I also say they are wrong. Our cars if we have Stang shorty headers bolted to our 5.0's.
87-88 T-bird H-pipe
I was hoping the length would be correct for the t-bird/cougar. I know all you have to do is have mid pipes made. But I was just trying to give the next guy a heads up. I already have true duals, just need a H or X pipe. I think it's a good price for a catted H-pipe.
87-88 T-bird H-pipe
Awesome this answer's my question i was just thinking about making a h-pipe for my bird lol.
87-88 T-bird H-pipe
With Mustang shorty headers,any Mustang H or X-pipe will bolt on.....but behind that,you have to have the ler shop do a little work.
I'm still saying that it will not bolt to stock Thunderbird/Cougar exhaust manifolds though for those wondering.
87-88 T-bird H-pipe
i bet it'll fit properly.. it's not meant to fit a mustang, so something is definitely different.. but nothing is certain unless you buy it and try for yourself.. do they have a non-catted H-pipe for a fox bird? i'd consider buying 1 if they do.. saves me from having to make 1.. just too lazy to look lol
87-88 T-bird H-pipe
I'm going with Vinnnie here ,  it wont fit a stock bird/ cougar
The Lincolns it has listed all have the shorty headers not the cast iron manifolds
 it also says it fits 4 cat applications , my bird only had 3
87-88 T-bird H-pipe
Quote from: turbo_88_XR7;345698
I'm not sure if they do. I'll check. What doesnt make since is the T-bird H-pipe is 52.5" long and the mustang H-pipe is 54" long. They are both made by catco, and they have differant part #s. The T-bird part DOES NOT cross reference with the mustang or the other way around. Weird!
87-88 T-bird H-pipe
Quote from: vinnietbird;345697
I might go this route but I'd rather run manifolds and a bolt on H-pipe for a street car. I've had problems with header gaskets in the past, and I dont think that they have that much advantage over manifolds on a street car that might make 250ish HP. Like I said I all ready have duals but I dont have a balance tube. I also dont like taking my car to exhaust shops anymore. I had a freind that owns an exhaust shop but we dont get along anymore and I dont trust anyone else. So it would be nice to find a bolt on part and Im hoping it could benefit the site.
87-88 T-bird H-pipe
Quote from: Bruce M;345702
 Well it certainly would be helpful , let us know if it works ;)
87-88 T-bird H-pipe
Quote from: hypostang;345699
Stock T-bird/cougars have a three cat Y-pipe. I think this replaces the Y or factory H on the Lincoln which had four cat H-pipes. If it replaces the Y-pipe on the T-bird/cougar, I think it bolts from the manifolds to the lers and completely replaces the y-pipe.
87-88 T-bird H-pipe
But the Lincolns with 4 cats have mustang style headers, It may well be a custom set up for Tbirds , I would suggest a phone call to them at the very least.
87-88 T-bird H-pipe
Quote from: hypostang;345706
But the Lincolns with 4 cats have mustang style headers, It may well be a custom set up for Tbirds  I would suggest a phone call to then at the very least.
Well do. I've got my fingers crossed. I'll try to call Catco directly tomorrow.
87-88 T-bird H-pipe
The difference is probably for the column shift 5.0 Birds...is it safe to ASSume all 5.0 Cougars were floor shift?
I've got a (stock) Mustang h pipe on mine, fits with no issues whatsoever, but I also have a T5 as well...
FWIW, the extra length in Cat/Birds is behind the front seat....shouldn't be one iota of difference in h pipes between the versions of Fox cars in regards to length...or at least that's my thought...
