Topic: MPG!!! My 1987 Bird 3.8 gets 22mpg. Is this the Norm??? (Read 4526 times) previous topic - next topic
I went 365miles on 16gallons gas in my ole 1987 3.8bird with 177,700miles on the odometer!!!  Is this pretty decent for a car this old. My 06 gt gets about 23mpg also if i keep my foot out of it but its 20years newer!!!
What do your cars get for mpg??? i run 89octane 10%ethanol.
1999 Trailblazer(wifes rig)
24 in the 'underbird
12 in the C-1500
35 in the Jetta
i get 23 with my 5.0 bird
So prob could be better then HUH?? I havent done a tune up or anything since i got it in October. Pretty much fixed the burned up alt wires,new alt,battery and changed the heatercore!!!
wow those are good numbers....
when my 88 was running it was getting about 20 TOPS and about 18 average...
and my 96 gets about 18-20 most of the time too....
and their both 3.8's:dunno:
....course I do have a foot made of a certain poisonous heavy metal.....
When I first got my cougar it averaged 18-22 depending on driving. Now with 165K I average 14-16.5. That's after the 3.45 gear change, dual exhaust, and HO upper with HO TB. I think there is something wrong with it but it still runs good. When I sawped in the mustang AOD with shift kit is when I noticed the decrease in MPG. It does'nt slip at all, it works great. It's not rich eather. I thought that everything that I've done would increase MPG but the gear change.
I get around 20-22 in my 88 5.0 Cougar.  More highway I do better than that.
Mike
On my 85 Cougar I used to have the 3.8 generally gave me 28 highway and 19 in town  3.08:1 rear end.  My 92 Tbird with the 3.8 is 18 in town and 26 highway. 3.27:1 rear end.
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
83 5.0 auto gets about 18mpg mixed town and highway driving (116,000miles)
85 2.3 turbo auto gets about 20-22mpg mixed driving (42,000 miles)
CoogarXR : 1985 Cougar XR-7
When my car was dead stock with 5.0 SO and 2.73's it would knock down mid-20's regularly.
Quote from: Bruce M;344870
my '88 has the HO 5.0 engine BBK 65 mm TB, headers with true dual exhaust, timing has been advanced and my AOD has a shift kit and i have 3.45 gears and i still get 23 mpg with it so i don't see why you can't get the same, what kind of tires are you running ? im running spoogeho ecsta's and i've always seen a lil increase in mpg with these tires.
Quote from: 50tbrd88;344886
What does it do for mileage now?  If...... you can keep your foot out of it??
Mine is stock now and will be fairly modified later.:evilgrin:
Mike
Quote from: Thunder Bantam;344888
Do they have flubber in them or something??
Mike
I'm running 215/65-15 BFG touring T/A at 32psi. They measure 26" tall. I'm going to pull the motor and replace the gaskets, seals, timing chain, oil pump, GT40 heads, and a HO cam. When I install the motor I'm going to replace all the sensors and cracked vaccum hoses. Maybe that will help. It's weird because it runs good. I havent checked tps voltage and the EGR is blocked off but if eather of those were the problem I would think it wouldnt run as good.
Quote from: mcb82gt;344891
nope just nitrogen lol
