Topic: Anyone running 18" wheels ? (Read 1290 times) previous topic - next topic
I decided if I convert to 5-lug I want to run the 18" Magnums from Wheel Replicas. Just curious if anyone did and what their experience was.  I'm keeping the suspension stock height if that matters.
Thanks
1974 Falcon XB-GT Coupe
1988 Thunderbird Sport
1962 Thunderbird convertible
1971 Mustang Mach1 429SCJ
There are quite a few of us that have 17. With the 17 I have a small side wall, and with the 18 it would probably be even smaller. May want to consider tire (rubber) cost, as the 18 may run more money.
*waves* Hi, 18's here!  Ride height is 27.25" up front and 28" out back from the ground to the top of the wheel well. The tires/rims work great, just get rims with the correct offset, otherwise you'll need rack limiters to eliminate the wheel rub in a hard turn. I run a 40 sidewall currently, but when these wear out I'll move up to a 45 sidewall.
