Topic: DIY stuff (Read 34466 times) previous topic - next topic
DIY stuff
UPDATED 31dec2016
if any questions call 304 772 3411
Treasure box of factory Brochures~american cars - thanks softtouch~~!
http://www.foxtbirdcougarforums.com/showthread.php?35821-Factory-Brochures-American-Cars
__________________________________________________
Various forum topics i feel are important and useful for troubleshooting or parts locating
fuel pump
255 lph Ford Focus SVT pump is what you need and it drops right in.
https://k-mansparts.com/ford-mustang-focus-255-lph-returnless-fuel-pump-m-pfs-204-detail.htm
Various Mods by Tom Renzo.....  THE RENZO FILES
affordable *****WAY BETTER THAN stock bolt  on brake parts replacement - thanks V8Demon
Get a set of 11 inch spindles, followed by this.....
thread is here>
http://www.foxtbirdcougarforums.com/showthread.php?38735-bleeding-the-master-cylinder
http://ssbrakes.com/i-10092994-disc-...1in-rotor.html
 I have that very kit on my front end minus the master cylinder. It uses the 73 mm calipers as opposed to the fox Mustang's 60's. I have 10 inch drums out back. Personally I'd use a master that has a reservoir and low fluid switch. You could always call SSBC and see what they would sell the kit without the master for....
Brake booster replacement stuff - thanks KitzKat & V8Demon
kitzkat=It sounds like your current master cylinder is a bit wore out
 If you plan to swap it out I would also consider swapping in a 93 cobra brake booster, it will give you that extra braking power you need
v8demon=Agreed.
 You can pick one up for about $100 from most places. You will need a 2 port to 3 port line addapter setup. I know you're quite resourceful and could most likely make your own if needed. MM sells a setup as well. http://www.maximummotorsports.com/Ma...tang-P673.aspx
 Cardone apparently carries a remanufactured version, however you would need to supply the reservoir. The reservoir carries a different part #, but I THINK you can use one from a standard fox Cougar/T-bird/Stang.
http://shop.advanceautoparts.com/p/c...3-P#fragment-2
 Dorman makes one as well. I believe it's new. It DOES come with the MC. Part # M390125
 Best price I can find is Summit. http://www.summitracing.com/parts/dhb-m390125
 $60 isn't bad at all.
Brake line mod !~ a must do for corrosion control and long life
http://www.foxtbirdcougarforums.com/showthread.php?37940-Brake-mods&highlight=
2.3L build and all kinds of neat little tricks
http://www.foxtbirdcougarforums.com/showthread.php?37811-Building-bruiser
Explorer code 13 solved, with a surprising but simple ending.... your average Mech would never find this problem.
http://www.foxtbirdcougarforums.com/showthread.php?37675-Fuse-13-Mistery-solved&highlight=
The throttle body with a riveting outcome!
http://www.foxtbirdcougarforums.com/showthread.php?37583-Strange-trouble!!!!&highlight=
Stuff I have linked
Re-Chrome plasic stuff with these guys - thanks Vinnie!!!
http://www.chrometechusa.com/index.html
The amazing Spark plug wire thread, forever change your perspective on plug wire quality ~thanks Seek!
http://www.foxtbirdcougarforums.com/showthread.php?38125-Time-for-some-new-ignition-wires
GT40 or otherwise good headers ~thanks thunderjet302
You need these:https://www.fordracingparts.com/parts/part_details.asp?PartKeyField=3616
Ran them with GT40P heads and I'm still running them with the Edelbrock heads I have now. Nice quality and won't rot out like other headers.
Ignition module relocation
http://www.foxtbirdcougarforums.com/showthread.php?37976-TFI-(ignition)-Module-relocation-JCassity-rendition
speedo speed sensor drive gear calculator ~ thanks aerocoupe~
http://www.sccoa.com/faq/speedgr.html
http://www.foxtbirdcougarforums.com/showthread.php?37648-Speedo-gear-for-AOD-after-changing-to-3-73-1-rear-gear/page2
Moon Roof information, pages from shop manual , all you need to know , thread about doing a new seal.  ~ by ChristmasGT, Jcassity & StenholmEngineering
http://www.foxtbirdcougarforums.com/showthread.php?37011-HOW-TO-Replace-Moon-Roof-Weather-Stripping&p=430314&posted=1#post430314
Restoration parts for your bird / coug and remember to use the stang as your base search for harder parts to find
http://www.latemodelrestoration.com/item/LRS-23504A/83-93-Mustang-Lower-Door-Hinge-Tension-Spring?utm_source=google-shopping&utm_medium=comparison-shopping&utm_campaign=google-shopping-v2&year=1983&gclid=CLHikJOVubwCFZPm7AodDWIAWQ
Sunroof / moon roof  seal replacement diy with pictures and gasket resource ~ thanks christmasGT!
the instructions:
http://imgur.com/a/W6lsM#0
The seal / gaset resource
http://www.sunroofdoctor.com/8788thunderbird.htm
EEC computer resources
http://www.oldfuelinjection.com/?p=3
http://www.foxtbirdcougarforums.com/showthread.php?35014-5-0-ho-ecu-computer-for-sale!!
Control Arm Bushing relacement
this includes a home made spring compressor that worked really great
http://www.foxtbirdcougarforums.com/showthread.php?16294-popping-and-squeek-quot-SOLVED-quot/page2
Control arm bushing part numbers for replacements from Napa with inner & outter diameters
http://www.foxtbirdcougarforums.com/showthread.php?16294-popping-and-squeek-quot-SOLVED-quot/page5
Fog Lamps
83-86 fox came with marchall lamps
87-88 fox came with Hella
link to parent company that makes the Hella fog lamps still available today~still pricey
http://www.foxtbirdcougarforums.com/showthread.php?35491-Marchal-Prices&highlight=hella
Mass Air Meter compatability with other existnig vehicles to your fox ~thanks thunderjet302~!!!!
http://www.foxtbirdcougarforums.com/showthread.php?32890-Explorer-MAF
thunderjet302~~Besides the stock Mustang 55mm units the following 70mm units will work with an A9P. Before I got my 73mm C&L MAF and 24lb injectors I used a 70mm MAF from a 1994 Lincoln Town Car. You need the MAF sensor from one of the Following Ford vehicles:
List of EEC-IV Processors for MAF Conversion
http://www.foxtbirdcougarforums.com/showthread.php?38369-List-of-EEC-IV-Processors-for-MAF-Conversion
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A
1985 5.0 CFI info ~ thanks Softtouch!
http://www.foxtbirdcougarforums.com/showthread.php?36574-High-idle/page2
seat cover and removal of covers shop manual pages
http://www.foxtbirdcougarforums.com/showthread.php?35936-shop-manual-technical-seat-information
Instrument Cluster, do your buttstuffog guages Lie?  Integrated Voltage Regulator
with buttstuffog guages / idiot lights and electronic speedo or with full buttstuffog cluster
http://www.foxtbirdcougarforums.com/showthread.php?34364-88-3.8-TBird-Cooling/page3
another IVR thread
http://www.foxtbirdcougarforums.com/showthread.php?34290-Need-IVR-help-on-instrument-cluster-**solved**&highlight=ivr
oil pan drain plug repair ideas
http://www.foxtbirdcougarforums.com/showthread.php?35785-oil-pan-plug-repair
ABS troubleshooting ~ thanks Chuck Warren
http://www.turbotbird.com/techinfo/TEVES%20II%20ELECTRO-HYDRAULIC%20BRAKING%20SYSTEM%2087-88%20TCs.htm
199mph electronic speedo modification- by bondocougar
http://www.coolcats.net/modifying/199speedo.html
Mileage correction electronic speedo-by bondocougar resources and confirmed by Thefoeyouknow
http://www.foxtbirdcougarforums.com/showthread.php?35555-Odometer-Correction
Lift point upgrade, ever had someone lift your car wrong?
http://www.foxtbirdcougarforums.com/showthread.php?31788-Lift-here-fool!!!!!!!!!!!!!!!!!&highlight=
center of molding mod, repair the gold, red or chrome look
http://www.foxtbirdcougarforums.com/showthread.php?24744-Confirmed-Exterior-molding-center-trim&highlight=
Heater core change so its always an easy job **FROM NOW ON
http://www.foxtbirdcougarforums.com/showthread.php?34998-AND-NOW!!!!-It-s-a-1hour-or-less-heater-core&daysprune=100
Relay adds to remove heat from headlamp and ignition switch
http://www.foxtbirdcougarforums.com/showthread.php?35095-Relay-bank-mod-COMPLETE-for-IGN-switch-Headlamp-and-Marker-lamps
results of my headlamp modification
http://www.foxtbirdcougarforums.com/showthread.php?35224-After-my-headlamp-modification&highlight=
HIGH BEAM *with * low beams on modification ~just an easy jumper wire.  ((applicable to those with auto lamps only))
http://www.foxtbirdcougarforums.com/showthread.php?35243-High-beam-with-low-beam-mod-with-an-easy-jumper-wire&p=408054#post408054
headlamp rework and remirror the insides, clear coat the outter lense
http://www.foxtbirdcougarforums.com/showthread.php?34549-Re-mirror-headlamp-interior&highlight=
Headlamp HID stuff  > thanks THEFOEYOUKNOW
http://www.theretrofitsource.com/product_info.php?products_id=227
http://www.jcwhitney.com/headlight-conversion-kit/c2824j1s17.jcwx
HID mod> Thanks TbirdX3
http://www.foxtbirdcougarforums.com/showthread.php?33121-%28New-Goodies%29Need-Your-Opinion-on-Headlight-Color!%28Lots-of-Pics%29&highlight=
Convert your not so accurate amp meter to a volt meter easily
http://www.foxtbirdcougarforums.com/showthread.php?34359-Ammeter-conversion-to-Voltmeter-R-amp-R-guts&daysprune=100
Cool down that big  resistor on the back of your buttstuffog instrument cluster.
This also applies to those with digital clusters except the resistor is smaller.
http://www.foxtbirdcougarforums.com/showthread.php?34327-buttstuffog-cluster-*solve-that-heat-problem*-on-the-big-3-long-reisistor&daysprune=100
Pull this thing out and throw it in the garbage (5.0 engines only)
http://www.foxtbirdcougarforums.com/showthread.php?35007-PCV-filter-on-the-5.0
EEC types and probably the only resource you need to figure out what computer you need
http://www.foxtbirdcougarforums.com/showthread.php?35014-5.0-ho-ecu..computer-for-sale!!
door armrest repair
http://www.foxtbirdcougarforums.com/showthread.php?34857-Armrest-repair&highlight=
Window getting off its track? why is this?  here is what we found
http://www.foxtbirdcougarforums.com/showthread.php?34261-window-off-the-track-i-think-we-solved-quot-why-quot&highlight=
where the water flows, rear wheel well inexpensive mod to prevent rear frame rust
http://www.foxtbirdcougarforums.com/showthread.php?31787-where-the-water-flows-Rear-Fender-Well-Mod&highlight=
Leaky trunk? stuff getting wet?
http://www.foxtbirdcougarforums.com/showthread.php?34827-Ever-get-water-in-your-trunk-for-no-reason&highlight=
door pocket repair
http://www.foxtbirdcougarforums.com/showthread.php?34860-Door-pocket-repair&highlight=
Need a new electrical connector? http://www.repairconnector.com/
Fuel sending unit (buttstuffog and digital cluster)
http://www.foxtbirdcougarforums.com/showthread.php?22137-fuel-sending-unit
Electronic Climate Control PM – thanks to “tr guy79”
http://www.foxtbirdcougarforums.com/showthread.php?t=26999
Casting numbers resource= by TurboCoupe5.0
http://www.mustangtek.com/FordDecode.html
Seat swap info
The Fox Stang,earlier Escorts,Fox Birds and Cougars....they all bolt in,but the tracks have to come from the Cats and Birds. SN-95 Mustang seats will also bolt to the Tbird/Cougar seat tracks.
Vent Visors and Smoke Headlamp covers > thanks 88turbo!!
83-86 smoke http://www.summitracing.com/parts/GTS-41327/
83-86 clear http://www.summitracing.com/parts/GTS-GT0205C/
87-88 smoke http://www.summitracing.com/parts/GTS-GT0219S/
also vent visors!!!!
Fan Clutch vs Electric fan study> thanks SEEK
http://www.foxtbirdcougarforums.com/showthread.php?24589-Electric-fan-FE-findings&highlight=electric%20fan
http://www.foxtbirdcougarforums.com/showthread.php?t=24589&highlight=electric+fan
replacement severe duty fan clutch  >>>>> thanks V8Demon
Wanna upgrade on the cheap without hunting for an SSP?
 Hayden part #2783 or Imperial part #215130. It's a "severe duty" unit. They're spec'd for a 1991 Dodge Dakota 4WD with the 5.2 V8. Advance auto carries the Imperial brand. Both Imperial and Hayden are the same company.
 Should run under $60......
Low fuel warning layout
http://www.foxtbirdcougarforums.com/showthread.php?t=24065
Heater Core coolant RESTRICTOR inside the feed line
http://www.foxtbirdcougarforums.com/...ad.php?t=23455
Power Antenna
http://www.foxtbirdcougarforums.com/...896#post265896
TV Cable adjustment (throttle valve) , aka> kick down cable, transmission kicker cable, passing gear cable ect.
Thanks V8Demon!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
http://www.foxtbirdcougarforums.com/showthread.php?18128-AOD-popping-out-of-gear/page2&highlight=tv%20cable
http://www.foxtbirdcougarforums.com/showthread.php?11690-Trany-cable-on-TB&highlight=TV%20cable
Seat and cover sources from the Pony
http://foxtbirdcougarforums.com/show...t=22400&page=3
Trunk lid struts < yep you heard me right
http://www.foxtbirdcougarforums.com/...ad.php?t=23346
Very good VSS (vehicle speed sensor) thread with respect to a HO Mark7 EEC
http://www.foxtbirdcougarforums.com/...ad.php?t=23336
TFI / stator troubleshooting
http://351winsor.com/joel/Ignition_Systems/tfi2.html
speed sensor gear source (at the transmission tailshaft)
http://crt-performance.com/speedometers.htm
Door Lock actuator source
http://www.foxtbirdcougarforums.com/...ad.php?t=23024
Fuel Injector Indentification post #28
http://www.foxtbirdcougarforums.com/...t=22388&page=3
headlamp resources
cougs & bird headlamps match up with 89>94 linc continental, per Vinnie- he doesnt see linc headlamps as dull as coug or birds
NEW HEADLAMP Assembly resource (tbird only) _thanks V8Demon
http://www.foxtbirdcougarforums.com/showthread.php?p=251896&posted=1#post251896
OEM linc cont equal for
This is a Pair of Lincoln Continental 1989-1994 or  Mercury Cougar 1987-88 Headlamp housing units. Application: 88-94 Lincoln Continental
87-88 Mercury Cougar
Ford Part # E80Y-13007-A and E80Y-13007-B
OEM List Price: $190.00 EACH
This is the lens housing only, NO mounting plate or bulb and socket.
Other active resources for HEAD LAMPs  ~ thanks Kafer 79!!
127$
http://www.oempartz.com/oem-part/ford/lens-and-housing-left/e7sz-13007-b
92$
http://www.varsityfordparts.com/OEMParts/ford-123/E/E7SZ13007A.html
92$
http://www.varsitylincoln-fordparts.com/OEMParts/ford-123/E/E7SZ13007A.html
180$
http://www.usaspareparts.com/parts/152-ford/1183917/e7sz13007a-e7sz-13007-a.html
The RARE 83/84 full electronic instrument cluster by lumpycheesman
http://www.foxtbirdcougarforums.com/showthread.php?t=21828&highlight=digital
Transmission fluid, what to use?
http://www.aa1car.com/library/atf.htm
Vaccuum diagram on your 5.0 fan shroud (including belt routing alternatives)
http://www.foxtbirdcougarforums.com/showthread.php?t=21824
Torque Converter conversation. very informative
http://www.foxtbirdcougarforums.com/showthread.php?t=20901&page=2
BATTERY draining over night (how to find the drain)
http://www.foxtbirdcougarforums.com/showthread.php?t=19254
NEED a shop manual? with all the wiring diagrams?
http://www.classiquecars.com/thunderbirdmancart.htm (thanks mwitkowski!!!)
or one for free... http://www.foxtbirdcougarforums.com/showthread.php?t=20492
WHAT MOTOR OIL ??? for the best amount of ZDDP (zink) to protect your engine and cam.
Rotella and Amsoil for the win! THANKS to dw85745, V8 Demon ,Turbo 88 and Amsoil dealer Turbot-bird
http://www.foxtbirdcougarforums.com/showthread.php?t=21617
Much information on various EVTM pages / sensors / Vac layout and lots of goodies
http://www.veryuseful.com/mustang/tech/engine/#Diagrams THANKS 88 Blackbird 5.0!!!
http://www.vintagebronco.com/newberry/pages/tech/efi/efi.html
lots of actual wire harness info including mustangs, bronco ect.
THANKS BLUE THUNDER!!!!
Headlamp lense cleaning (yellow to clear again!!) thanks Cougar5.0!!!!
http://www.lincolnsonline.com/tech/00019.html
1988-93 Continentals use the same headlamps as 87/88 cougs> thanks watchdevil
1988 EVTM by "thefoeyouknow"
http://trinom.org/www/foxtbirdcougarforums/1988_Thunderbird_EVTM.exe
1987 EVTM (ELECTRICAL VACCUUM TROUBLESHOOTING MANUAL)
Full blown manual including front/rear covers and color schematics.
or..
http://s47.photobucket.com/albums/f162/jcassity_bucket/
1986 EVTM by "trinom"
https://picasaweb.google.com/116504312330534460153/EVTM?authkey=Gv1sRgCMuUiNWbkfzJiQE
Various sensors and understanding how they work (THANKS ISPD!!)
http://www.fordfuelinjection.com/
Mileage change to zero on buttstuffoge speedo by "masterblaster"
http://www.foxtbirdcougarforums.com/showthread.php?t=4855
Fuse panel for the Ford Thunderbird or Mercury Cougar 1983-1987
http://www.foxtbirdcougarforums.com/showthread.php?p=228182&posted=1#post228182
Smog Bypass 5.0L "SHORT BELT"
http://www.foxtbirdcougarforums.com/showthread.php?t=17236
77’’ belt install on stock 5.0 with smog bypass
http://www.foxtbirdcougarforums.com/showthread.php?t=26714
Power Door Locks
http://www.foxtbirdcougarforums.com/showthread.php?t=19141
Great resource for headlamps and lense body parts (thanks JermemyB and V8demon)
http://www.foxtbirdcougarforums.com/showthread.php?t=16364
http://www.foxtbirdcougarforums.com/showthread.php?t=18464
EATC wiring diagrams along with code 88 and 02
http://www.foxtbirdcougarforums.com/showthread.php?p=205277&posted=1#post205277
Duraspark wiring info
http://www.foxtbirdcougarforums.com/showthread.php?t=17135
Base dash cluster with digi speedo and Full digi cluster wiring
http://www.foxtbirdcougarforums.com/showthread.php?t=17053
EEC wiring 5.0L SEFI
http://www.foxtbirdcougarforums.com/showthread.php?t=15656&page=3
Blower motor relay modification to take  heat off the selector switch and the speed control switch.
*be sure to read post 24 about our factory switches ~thanks tom renzon~!!
http://www.foxtbirdcougarforums.com/showthread.php?34264-Protecting-your-blower-motor-switch-%28non-EATC%29/page4&highlight=manual%2C+heater
Blower motor troubleshooting Blower has HIGH speed only and wiring diagram
http://www.foxtbirdcougarforums.com/showthread.php?p=220320#post220320
Blower motor troubleshooting and wiring diagram
http://www.foxtbirdcougarforums.com/showthread.php?t=17041
Various rear end info,, thanks Jim Miller , JeromeyB and ChuckW
http://www.foxtbirdcougarforums.com/showthread.php?t=13253&page=3
Engine Codes, pulling codes and how to do it.
http://www.therangerstation.com/tech_library/OBD_I.html
Radio ect wiring diagrams
http://www.foxtbirdcougarforums.com/showthread.php?p=181940#post181940
Cruise Control troubleshooting (my personal experience)
http://www.foxtbirdcougarforums.com/showthread.php?t=17452
Cruise Control Problems
http://www.foxtbirdcougarforums.com/showthread.php?t=14879&highlight=cruise+control
Guages / indicators fuel pump , temp, oil, low fuel , brake
http://www.foxtbirdcougarforums.com/showthread.php?p=179608&posted=1#post179608
Power Seats
http://www.foxtbirdcougarforums.com/showthread.php?t=16213
3g alternator upgrade 3.8, 5.0, 2.3
http://www.foxtbirdcougarforums.com/showthread.php?t=13641
please read this if you own a 2.3 and consider a 3g swap "death of a tbird
http://www.foxtbirdcougarforums.com/showthread.php?t=15802&highlight=3g
Auto Lamp info
http://www.foxtbirdcougarforums.com/showthread.php?t=15760
Rear end 7.5 and 8.8 change out (this thread covers it all!!!)
http://www.foxtbirdcougarforums.com/showthread.php?t=3664
2.3 Turbo Starting circuit
http://www.foxtbirdcougarforums.com/showthread.php?t=16340
5.0 Starting circuit
http://www.foxtbirdcougarforums.com/showthread.php?t=11603
Power seats
Electric fan with relay and toggle switch
http://www.foxtbirdcougarforums.com/showthread.php?t=15952
MasterBlaster’s neat  link
http://www3.telus.net/neat/
EECIV self test connector and info
http://www.foxtbirdcougarforums.com/showthread.php?t=10835
Main light switch info
http://www.foxtbirdcougarforums.com/showthread.php?t=11401
Headlamp wiring
http://www.foxtbirdcougarforums.com/showthread.php?t=11426
Wiper system
http://www.foxtbirdcougarforums.com/showthread.php?t=11615
Illuminated Entry
http://www.foxtbirdcougarforums.com/showthread.php?t=11601
Multifunction switch continuity test
http://www.foxtbirdcougarforums.com/showthread.php?t=11644
Turn Signal / Hazard lamps
Power windows
http://www.foxtbirdcougarforums.com/showthread.php?t=11779
__________________________________________________ _
index............
****LOOK FOR TOPIC THEN SCROLL DOWN TO ITEM
interesting quote from Thunderchicken indicating you can never get rid of your car even if you sell it.
"Fox Birds and Cougars are like herpes. You can never get them totally out of your system. No matter how long you go without showing any symptoms, they will flare up again at some point"
What ho EEC options are there by the code on the lable? By -infamouspa
87-88 bird differences- turbocoupe5.0
Ignition switch defects
BALL JOINTS done without a press.. http://www.foxtbirdcougarforums.com/showthread.php?p=252460&posted=1#post252460
3g alternator upgrade 3.8/5.0 only.. http://www.foxtbirdcougarforums.com/showthread.php?t=13641&page=2
Is the 5.0 a roller engine or not
302 intake differences MUST READ!!
fuel sending unit info
Blower Motor HVAC only runs on HIGH
Keyless Entry tid bit
EATC or ATC codes and troubleshooting
Web based resources
Squeeks, find em quickly
Diagnostic testing with codes 3 step method with 2 and 3 digit codes
drive shaft compatability
Distributor check and reset
Power Window troubleshooting
Fuel pump testing (intermittant or no pump sound)
Fuel pump, Want an external one?
Head gasket tid bits
Door weather striping
head gasket repair
valve cover repair
Cruise control slip ring test
Instant test light
Injector balance test
Idle control motor (ISC adn idle tracking switch check) 3.8 and some 5.0 engines
fuel pres test
EGR/emissions solenoids
EGR test and EVP sensor test
ECT sensor test
smog pump delete and some other goodies
Coolant Temp sensor (2wire)
Trip minder conversion
Fuel injection configuration Batch vs Bank fire
trottle body cleaning (cfi)
fuel injector cleaning
timing chain slack measure
Dash cluster removal
tps test throttle position sensor
leak down tester
speedo mod (beyond 85mph)
Digital Speedo Troubleshooting
Tach/Multi guage diagnostic
O2 sensor check
Map sensor check
No Spark
No spark, TFI CONN check
Coil Check
stator check
TFI MODULE TEST
fuel injector id
Spindal wear and tear
head cam piston info (CONVERSATIONS ON COOLCATS.NET MESSAGE BOARD)SEE DETAILED INFO BELOW)
Camshaft engineering info
Torque converters
REAR END INFO
Rack/pininon removeal and tid bits
Tie rod end inspection and inner tie rod end adjustment (adjustment in the knuckle also)
Ball joint replacement
Tailshaft bushing check and replacement (including the quick replacement By TurboCoupe50 ,this is cool!)
Checking the fuel pump relay (in/out of car test)
misc speedo gear info
309/406/427 tid bits
misc engine info (various cubic inch blocks and specs)
misc casting number info
GT heads,JUST ABOUT EVERY FORD ENGINE LONG BLOCKS WITH CASTING NUMBERS FOR HEADS/BLOCKS/CRANKS ECT.
_________________________________________________________________________
mass air eec identification  ~  Thanks Aerocoupe~~~!!!!!!!!!!
I am pretty sure this list is complete but if any corrections are needed let me know and I will revise. I scoured several Mustang sites and several tuner sites and finally started seeing enough of the same thing here and there that I feel comfortable with publishing the list. I am not saying it is 100% correct but it is as far as I know.
Manual Transmisstion EEC-IV's:
 A9L - 88-92 5.0 Mustang
 A9M - 89-93 5.0 Mustang
 D3D1 - 89-93 5.0 Mustang
 S0Z - 89-93 5.0 Mustang
 A3M - 93 5.0 Mustang
 A3M1 - 93 5.0 Mustang
 A3M2 - 93 5.0 Mustang
Automatic Transmission EEC IV's:
 A9P - 89-92 5.0 Mustang
 A9T - 89-93 5.0 Mustang
 C3W - 93 5.0 Mustang
 C3W1 - 93 5.0 Mustang
California Mustang EEC-IV's:
 A9S - 88-93 5.0 Mustang
 8LF - 88-93 5.0 Mustang
 8LD - 88-93 5.0 Mustang
Cobra Mustang EEC-IV:
 X3Z - 93 5.0 Mustang (24lb injectors with OEM calibrated MAF)
 With that I would strong caution that the California EEC be not used unless you are going to use an editor as they have some inherent programming in them to deal with CA's emissions laws. The same goes for the Cobra's EEC as it was specifically meant for that car unless you can come up with the matching OEM MAF and 24lb/hr injectors.
 Under the manual transmission list you will see the A3M family and under the Auto list you will see the C3W family which show 93 only. This is due to them being the replacement EEC offered by the dealerships. So for example, if you would have brought in a 1991 5.0 Mustang with a T-5 and the A9L EEC was fried the Ford dealer would have most likely replaced it with an A3M processor.
 I did this as I see a few guys going MAF and it seems like everyone thinks that the only processors out there are the A9L and A9P and those that have them want a mint for them. We still should not be paying over $100 for a working unit and yes they can be found for this on the Mustang forums. I typically have much better luck on the "local" Mustang forums than on the "national" ones like the Corral as those get jumped on really fast.
 Darren
______________________________________________________________________________
Hmmm..I am positive i bought it from a Fox Body mustang parts dealer..On cool cats main website..Go to ? Um never mind..Here it is
EEC-IV 5.0 HO Computer
Here's the brains of it all, literally—the stock Mustang 5.0 computer. You should be able to find one at a salvage yard, swap meet or online for a reasonable price. Beginning in 1987 Ford began using a calibration code on each computer, with the code stamped on the top. For speed density, these are the computers that you can use (all listed for automatic transmissions):
■DA1 (1987-88 Mustang)
■DB1 (1987-88 Mustang)
■DX3 (1987 Mark VII)
■VL2 (1987 Mark VII)
■DY3 (1988 Mark VII)
■D9S (1988 Mark VII)
THESE WILL ALL FIT YOUR CARS..
To fix the lighting.
Remove dash fascia (varies by model)
Remove 4 screws securing EATC module
Unplug 3 plugs from back (One is on the side for Rear Defrost)
Remove (2) 1/4" bolts from defrost plug
Remove (4) Phillips screws from housing. Two in bottom rear, Two in back side of the front lip
Slide rear housing off of EATC module
This is where things vary... If you'd like, just remove the two bulbs and replace (194 I think)
If you dont want to risk breaking the bayonet mount, and/or want to clean it while its out, read on.
Remove (5) black Phillips head screws, holding circuit board to the front panel
If you are JUST replacing the bulbs, pull them out and replace
If you want to clean the buttons, remove the (2) Phillips screws holding the light bar, and then tip the face over and the buttons will fall out.
While you have everything apart, if any of your buttons are getting hard work, try gently rubbing an eyeglasses slotted screw driver between the rectangular contacts, and the dimple that they connect with. You want to se any build up off of the dimple and metal contacts without damaging it. I have also used the end of a round tooth pick. You actually have to be pretty darn rough with it to break the metal contacts off of the board.
If anyone wants this done, but doesnt want to deal with it, or is worried about breaking something, pull you module, and ship it to me with $20 and return postage... I will fully clean, and replace lighting.
(I actually just did that all from memory...)
-Shane
PS... Make sure you put your rear defrost switch back in the right way, or you will be really confused when you try to use it, and "ON" is towards the bottom (Squiggly arrows point up)
The '87 uses a Ford alt while the '88 uses a Hitachi alt... The 5 speed computers are different, on the factory setup, the '87 only has full boost in 1st & 2nd... The trim pieces on the inside door handle pulls are different, 88's have some plastic chromed trim, the '87 are all interior color... EATC control buttons are labeled slightly differently, but that's all '87 to '88 models... The engine identifier code in the VIN, switched from "W" in '87 to "T" in '88... Lastly the '87s all had metal trim around the back window, early '88s built prior to about about mid Nov '87, have the metal as well...
turbocoupe50
Ford stated the problem with the '88-'92 switches was the contacts inside were so closely spaced, the the grease could conduct electricity between the contacts and catch fire(electricity + resistance = heat)... This is why they sometimes burn in the middle of the night, for no apparent reason... The problem started occurring when the switches were only a few years old and the grease had been subject to the switch arcing when turned through its positions... The '87-earlier switches had a larger spacing between contacts that was wide enough to supposedly prevent the "arc across" issue... The newer switches went back to a larger contact spacing...
thunderchicken
The new switches are identical to the old ones. The only difference would be the part number stamped on the switch - the original switch would have a part number that starts with "E", while the new one would have a part number that starts with "F".
You won't see any exterior signs of problems unless the switch has actually burned (I had one burn a hole right through the side). The problem with the switches is in the contacts (plates) inside the switch. They wear over time and the copper filings that wear off them builds up between the plates, causing shorts. At the same time the wearing plates make poor contact with the slider (the thing that moves when you turn the switch on), and poor contact causes heat.
Regardless whether your current switch is an E (old) or F (new), if you're having symptoms of a bad switch, replace it. Don't cheap out with a used one, get a new one.
As for what problems to look for when a switch fails, you've already experienced one of the early symptoms. Another common symptom is an engine that starts but the heater, gauges and turn signals don't work. Basically, any time you have multiple systems fail at the same time (such as heater, turn signals and gauges) it's usually the switch.
There is nothing you can do to prevent the problem altogether, aside from rewiring the "power distribution" circuits that feed the accessories in the car (which I have done in my car, but it is not a job for a novice). A new switch still has the inherent flaw, but it should still last many years before failing again.
BALL JOINTS done without a press http://www.foxtbirdcougarforums.com/...d=1#post252460
Remove Balljoint
-loosen lug nuts
-jack up car on sub frame
-insert jack stand in place of jack
-remove wheel,caliper,rotor
-remove tie rod end (loosen nut till nut is flush with tie rod end stud, beat on nut till tie rod end pops out, remove nut all the way and swing tie rod out of the way.
-rotate strut to access balljoint nut
-loosen balljoint nut leaving nut on by a two or three threads
-Beat on nut with hand sledge
-control arm will pop down be stopped by nut.
-jack up control arm from the side about 1/2'' or so
-insert jack stand on the outter most part of control arm (sort of use the top hook part of jack stand to grab the outter round part of jack stand
-lower control arm onto jack stand
-remove nut on ball joint
-lift spindal/strut assembly up and out of the way
**all control arm presure is now on the jack stand
-beat on ball joint until it pops out.
Install Balljoint
-do not install zerk fitting yet
-place balljoint in hole and tap into place getting it centered lined up. dont be a panty wuss, just a few good hard strikes on opposite sides alternating will get it started. just feel and look at the "ball joint stop lip" keeping it from getting cantered one way or the other.
-jack up side of control arm taking presure off jack stand
-relocate jack stand to side of control arm and lower
-center block of wood with small / thick metal shim under ball joint.
-lower arm till ball joint bottom makes contact with shim only when jack is removed.
-using hand sledge, beat on outter most part of control arm. you are beating the arm down over the ball joint.
-inspect to see progres and repeat above process.
-you will see the ball joint "stop lip" gap decreasing as it seats.
-once satisfied the ball joint is in, you might have a 1/16'' gap between the control arm and the ball joint "stop lip".
-install ball joint boot making sure it snaps all the way around
-grab spindal assembly and lift up and set on ball joint stud.
-install nut and tighten
-remove wood block
-beat on bottom of ball joint a couple more times
-check ball joint nut again
-install zerk fitting and grease till you feel/see the boot swell
-the rest is reverse order on the rotor,caliper and tie rod end.
-remember to debur tie rod end stud / nut and test fit tie rod end nut prior to putting it on.
3g alternator upgrade step by step (3.8 and 5.0 only)
-96 ford Taurus for voltage regulator or brush kit.
At this point you have a 3g alt and have made it fit as well as trim work done to the mounting ect.
Cut off the connector that has the wh/bk and two bk/or leads leaving 2'' of slack incase you mess up.
Add a connector to the end of the wht/bk lead and hook that up to the sense part of the alt.
Cut and add a ring lug to the end of the y/wht wire and connect to alt output
Remove yellow wire from the battery side of the starter relay.
Cut off the two headlamp harness leads (they have fuse links) that splice into the yellow side of the splice.
Connect the headlamp wires up to the starter relay on the battery side via a couple or one ring lug.
You now should be holding a harness that has two black/org and one yellow wire, keep it for spare parts.
Connect and ring lug a 6awg or better flex power cable from the alt output to the battery side of the starter relay.
Plug in the small "D" shaped connector with the Grn, Wht and yel wires. The green wire remained the same.
DONE!!
Is the 5.0 a roller engine or not??
pull a push rod out
a roller 5.0 engine will have 6.27" pushrods
a non roller will have 6.9" pushrods
>>>> turbocoupe50
302 intake differences (thank you user name "jim Miller"
first off, visit this site with pics included.
The way to identify the vast majority of lower intakes is to look at the rear driver’s side  and find the cast in name of the supplier. You will find names such as SAC, SAC 1, SAC 2, SAC 3, SAC 4, ALCAN, and CAE
. The SAC casting are sand mold castings which have a rough sand finish and use only one mold per intake. The CAE and ALCAN lower intakes are investment cast which re-uses the mold and results in a smoother finish on the intake with less core shift. The ALCAN has a distinctive wire mesh pattern in the top  valleys (see above and below photos).
When ported properly to a stock replacement gasket size the SAC, ALCAN, or CAE intakes will flow over 200cfm average:
There is another supplier of lower intake to Ford and I still do not know what model cars Ford installed these intakes on from the factory. The casting mark is not on the back driver’s side  like all the others. If you turn these intakes over and look at the bottom of the cooling water crossover passage, you will find an “M 3” or "M 2" cast into the bottom of the passage. See the picture. The part number of this intake is RF-E6SE-9K461-D2A with the D2A indicating this intake. ALCANs and CAEs have D3A and the SACs have D5A. Knowing these numbers can make finding the intakes much easier in the junk yard as the part number is on top the cooling water passage at the front of the intake.
The significance of these various intakes is in their potential for porting. The #1, #5, #2, #3, #6 and #7 runners tend to get thin on the short side (back of the “knee” of the curve) and if you’re not careful, you can break through the casting on the top exposed surface of the runner while porting. So, the more material that is cast into the exposed top of the runner, the less chance you have of breaking through the casting. Of course you can TIG weld a puddle of aluminum in the area to avoid breaking through, but you loose the 100% stock look of the intake. Granted it is not easy to see the welds if you don’t get carried away but it is detectable upon inspection.
If you want the best lower intake to port for a stock intake application, you need to find one of the M3 castings. Their runner cross section at the head  is smaller and more restricted than the other 5.0 lower intakes, but they have much more meat in the casting for porting. This is easily seen when you look at a runner such as the #5 runner where it meets the head . See the picture of a SAC, ALCAN and M3 intake casting.
The SAC intakes have the least amount of material, the ALCAN and CAE have more, and the M 3 intake has the most. The M3 has enough material to produce a 1250 size cross section at the head  without having to weld the top of the runner. It holds potential to produce the best flow un-welded. Happy Hunting!
Fuel sending unit info
Conventional "buttstuffog cluster"
87 Evtm page 127 or 129 shows
Empty - resistance - 60 to 86 ohms
Full - resistance - 8 to 12 ohms
Fully Electronic cluster
87 shop manual 33-05-23 troubleshooting step TJ6 shows
Empty- resistance-9-12ohms
Full-high resistance - 154-160ohms
88 turbo was able to verify his fuel guage was working properly. Just unplug the gray two wire connector "C491" under the package shelf accessable in the trunk. The two wires are yellow/white and a black. Insert a 10 ohm resistor in tehplug crossing the yellow/white and black wire. Make sure you have jumpered the fuel guage side of the wiring harness with this 10ohm resistor. Turn on your key and the needle should peg showing a full tank. This test was performed on a thunderbird turbo version. I wouldnt think it would be different for 3.8 or 5.0 engines but one never knows.
lay on your back under the tank
look to the right
find a two wire harness
one wire is yellow / white
the other is likely black.
this should be the sender harness
grab harness and follow its path up
it should be going up and finally under your package shelf in the trunk
package shelf-in trunk up near speakers
get in trunk
look for a connector with yellow white wire and a black
unhook connector
one end goes to your dash guage
the other goes to the sender
disconnect sender connector
connect red meter lead to the yellow white
connect black meter lead directly to the metal tank***
do not deviate from the above two steps or reading may be wrong
set meter to resistance and read
jot down that number you get
add 5gal of gas
read sender
if there is a change then the sender is assumed to be good.
To test the guage, insert a paper clip in the connector (C491)
This connector is the other end you disconnected leading to the guage
turn on key
gas needle will peg if its good
gas needle will peg if its a conventional cluster
gas needle will go to empty if its a digital cluster sender
go to my diy link below for details.
go to my electrical tech sticky "1987 evtm" page 129 for wiring diagram.
post your results
You can define what sender you have based on your readings as well as determin if it works.
I have often thought that if one puts a digital cluster sender in a conventional dash car, the leads on the guage can be flipped there to compensate for the tank circuit,,,,,,,,,,(you getting this daminc?)
ZERO DOLLAR FIX
**warning, after this repair, do not touch internal parts, BURN HAZARD***
Remove the glove box
locate the resistor mounted in the air box
It will have one connector and is mounted by two screws
pull it out and stare at it real close
there will be small springs mounted to clips
These springs are the resistors which limit fan speed
There will be another tiny tiny device that looks like a electronics part
This would be a fuse and you will remove it now
Insert in a section of 30awg wire or smaller in place of the fuse
This thin section of wire will act as the "new" fuse
Test fan
all speeds should work
When debris gets built up inside the fan causing it to be "heavy", the fuse will blow again.
Pushing 7,8 and 9,0 together signals the "Lock" function according to user billyF17.
ATC Codes
possible of codes 1-15, code 88 is system passes test
Code trouble code 2 displayed
**assume first off that your Floor Panel is jammed with debris from buildup ect which may prevent the door from moving freely and cause this code.
**we are going to bypass the EATC system in the following steps
1 Disconnect the two identical 14 pin conn's at rear of ATC
2 Turn Ign switch to Run
J1= (or conn C124) pass side control assembly, pin 11 should be blank, pin 1 should be BR/LG
J2= (or conn C126) driver side control assembly, pin 12 should be blank, pin 1 should be LB/RD
**verify you have a good ground on J2 pin 4 via continuity check from vehicle chassis to the conn.
3 Supply yourself with two jumper wires and perfrom the two tests.
*caution, you are going to supply Direct battery voltage to the Floor panel via pin J2-8 to test that it moves. Make sure you have power on this pin. The door should move when the J2-4 is made which is ground.
4 jumper J1-6(pink) to J2-8(+bat LB/Pk AND J1-9(wh/y) to J2-4(bk)
*******The book says to do this test quickly, as in no more than one second or you may burn something up.
If door swings fully in one direction the proceed to next step by reversing the polarity to swing door in opposite direction
5 jumper J1-9 to J2-8 AND J1-6 to J2-4.
if door swings opposite driection fully, proceed on.
Resistance check of Floor Panel sensor **J1 only***
the sensor is nothing more than a variable resistor with three legs.
Pin 4 is one side of the resistor, pin 5 is the other side of the resistor, pin 13 is the moving center tap.
6 total resistance of sensor at J1 pins 4 to 5 should be about 500-600ohms
7 This step is kinda tricky and really depends on which position your door is in at this moment in time, especially if there is debris in the duct work that prevents the door from moving fully.
anyway, resistance from J1 pins 13(R/lg) to 4(BK/W) should be 70-550ohms
Resistance from J1 pins 13(R/lg) to 5(LG/O) should be 200-500 ohms.
8 Here is what i would do if you can manually move the door with your hand or something. Treat this sensor like it were a throttle position sensor.
from J1 pins 13 to 5 with an ohm meter, measure resistance and manually move the door slowly watching the resistance scale increase and decrease smoothly.
from J1 pins 13 to 4 with an ohm meter, measure resistance and manually move the door slowly watching the resistance scale increase and decrease smoothly.
get a couple cans of wd40 and toss them in the car with you
plan out a decent drive that you know for a fact will produce the squeeks you hear
before you take off, spray down on suspension piece part in the area you hear the noise
go for a drive, if the problem is still there, stop the car and spray a new area or connection
when the problem goes away, you just located your squeek.
Web based resources
**my favorite>> http://www.therangerstation.com
**http://www.veryuseful.com/mustang/tech/engine/
**For more detailed info and other options to pulling codes, visit the Tech library at therangerstation.com. Scroll down on the left and click on EEC-IV Diagnostics under the "computer" section.
To pull codes, locate your diagnostic connectors usually on the driver side engine bay.
There are two connectors, one large female one has 6 pins sort of triangle shaped. 4 pins along the bottom row and 2 on the top row. Count these pins by looking into the connector and counting each row left to right.
The second connector will be a single wire female plug as well located near the 6 pin female plug.
Below will be instructions on how to use a jumper wire to connect the "sig rtn" lead to the "sti". Here is where you would use a paper clip to make this jumper. The SIG RTN connetion is on the large connector , top row , right hand pin. (top row has two pins). The "STI" conneciton is the single wire lead near the diagnostic large connector. Read below and install the jumper when told to.
MEMORY CODES
Memory codes are problems that the computer has noticed in the past. If for example there was a loose wire to a solenoid that only lost contact while driving but was making contact while testing the system there would be NO HARD FAULT CODE. The code would show up IN MEMORY. The same would happen for a sensor that only went out of range occasionally. Memory codes come out AFTER the separator pulse.
NOTE: The computer will erase the memory after a certain number of engine re-starts if the problem does not repeat itself. The number of re-starts varies from 20 to 80 depending on the year of the vehicle. The later models keep memory longer.
Clearing Codes
These codes are kept in memory for 40 warm up cycles. To clear the codes for purposes of testing or confirming repair, perform the code reading procedure. When the fault codes begin to be displayed, de-activate the test by either disconnecting the jumper wire or releasing the test button on the hand scanner. Stopping the test during code transmission will erase the continuous memory. Do not disconnect the negative battery cable to clear the codes; the keep alive memory will be cleared and a new code (19) will be stored for loss of PCM power.
Below will mention using a test light instead of the check engine light during the instructions you will read. If you would like to be up near the engine and pull the codes then hook up the jumper wire when instructed and as described above. NOW, hook up a professional or riged up test light from the positive batter terminal to the large test connector , bottom row 2nd pin (STO pin) counting left to right looking into the plug. When you follow the steps below, the test light will strobe codes and how to decode them will follow below. I have used a 12dc buzzer i got out of an old microwave that gives me an audible tone. This makes it easier to focus on the paperwork end of the task so im not looking back and forth at a light and paper second guessing myself.
>>>>>>>>>>>>>>START HERE
STEP 1
Malfunction Indicator Lamp (MIL) Method OR CHECK ENGINE LIGHT METHOD
The Malfunction Indicator Lamp (MIL) on the dash (Engine Light) can be used to retrieve the stored codes. This method does not allow for any system investigation. This should only be used in the field where quick checks are needed. Follow the directions previously given for the scan tool procedure. To activate the tests, use a jumper wire to connect the signal return (SIG RTN) pin on the diagnostic connector to the Self-Test Input (STI) connector. The self test input (STI) line is the separate wire and connector with or near the diagnostic connector. Codes are transmitted with a pause between flashes. Code 32 would be sent as 3-flashes, a pause and then 2-flashes. A slightly longer pause separates the codes. The only way to repeat the code is to recycle the system. The Continuous Memory Codes are separated from the other codes by 6-seconds, a flash and then another 6-second delay. Compare the 2-digit and 3-digit Diagnostic Codes with the appropriate chart.
STEP 2
KEY ON ENGINE OFF (KOEO) TEST ************KOEO
NOTE: On 4.9L trucks with a manual transmission hold the clutch pedal in during this test.
On Diesel engine trucks hold the throttle to the floor during this test.
1. Make sure engine is fully warmed. If in doubt, run engine at 2000 rpm for 2 minutes.
2. Turn ignition off and wait 10 seconds for system to shut off. Make sure A/C is off and transmission is in Park (automatic) or Neutral (manual).
3. Hook up light and jumper (or a tester if you have one). Turn key to ON (do not start engine).
4. Fast Codes are output (ignore fast light flashes).
NOTE: Unhook self test input jumper (or tester if used) at any time during code output to erase memory.
5. Read hard faults.
6. Separator Pulse.
7. Read memory codes.
8. See code explanations and check components as necessary.
Use FIRST CODE OUTPUT and retest after any repairs are made.
STEP 3
KEY ON ENGINE RUNNING (KOER) TEST ***************KOER
3. Hook up light and jumper (or tester if you have one).
4. Make sure vehicle is safe to run and start engine.
5. Engine I.D. should be output.
6. Step on brake and turn steering wheel 1/4 turn. If the vehicle has an overdrive cancel switch, push it.
7. If a "Goose" pulse is received, move throttle quickly 1/2 way down and release.
8. Fast Codes are output (ignore).
9. Read codes.
10. See code explanations and check components as necessary. Use FIRST CODE OUTPUT and retest after any repairs are made.
2 digit Code Definition
11 System checks OK
12 Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
13 (O) ISC did not respond properly (extends to touch throttle then retracts for KOEO) - ISC
(R) Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
(M) ISC sticking, open ITS circuit or TP sticking
14 Ignition pickup was erratic - Ignition Systems
E4OD Transmission diesel RPM sensor - Diesel RPM sensor
15 (O) No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
(M) KAM (pin 1) was interrupted (was battery disconnected ?)
16 1.9L & 2.5L - Throttle stop set too high - IDLE or Idle Set Procedures
2.3L - RPM's too low - IDLE
(O) Electronic ignition - IDM circuit fault - Ignition Systems
17 1.9L & 2.5L - Throttle stop set too low - IDLE
18 (R) Check base timing & advance function - Timing Tests
(M) Ignition TACH signal erratic - Ignition Systems
19 (O) No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
(R) Erratic idle during test (reset throttle & retest) - Idle Set Procedures
Electronic ignition Cylinder ID sensor/circuit problem - Ignition Systems
21 Engine Coolant Temperature (ECT) sensor out of range - ECT
22 MAP (vacuum) or BARO signal out of range - MAP
23 Throttle sensor out of range or throttle set too high - TPS
24 Intake Air Temperature(ACT) (IAT) or Vane Air Temperature (VAT) sensor out of range - IAT VAT
25 Knock sensor not tested (ignore if not pinging) - KS
26 Mass Air Flow (MAF) or Vane Air Flow (VAF) out of range - MAF VAF
Transmission Oil Temperature (TOT) sensor out of range - Transmissions
27 Vehicle Speed Sensor problem - VSS
28 Vane Air Temperature (VAT) sensor out of range - VAT
2.3L w/Electronic Ignition - Cyl ID, IDM low or right coil pack failure - Ignition Systems
29 Vehicle Speed Sensor problem - VSS
EGR CODES DEPEND ON WHAT SYSTEM TYPE THE VEHICLE IS EQUIPPED WITH:
EVP is for vehicles equipped with EGR solenoid(s), with or without an EVP sensor
EVR is for vehicles equipped with an EGR Vacuum Regulator (EVR) and an EGR Valve Position (EVP) sensor
PFE is for vehicles with Pressure Feedback EGR (PFE) sensor and and an EGR Vacuum Regulator (EVR)
If you don't know what type of system you have, go to the EVP heading, which is the first one.
There are pictures under the different headings to help you identify the system.
31 EVP - (O, R, M) EVP signal is/was out of range - EVP
EVR - (O, R, M) EVP signal is/was low - EVR
PFE - (O, R, M) PFE signal is/was low - PFE
32 EVP - (R) EGR not responding properly during test - EVP
PFE - (R, M) PFE shows low pressure, EGR not seating or memory, not seating intermittently - PFE
33 ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
34 EVP - (R) EGR did not respond properly during test - EVP
EVR - (O, R, M) EVP sensor is/was high - EVR
PFE - (O, R, M) PFE sensor is/was out of range - PFE
35 EVP - (R) Engine RPM's too low to test EGR system - EVP
EVR - (O, R, M) EVP sensor signal is/was high - EVR
PFE - (O, R, M) PFE sensor signal is/was high - PFE
38 Idle Tracking Switch signal was intermittent - ISC
39 Transmission Torque Converter clutch not engaging - Transmissions
40 SERIES FUEL/AIR INJECTION CODES ON VEHICLES WITH DUAL OXYGEN SENSORS REFER TO THE RIGHT OR REAR SENSOR. EXCEPT: 1984-1988 3.8L ENGINES: LEFT SENSOR
41 (R) System lean - Fuel control
(M) System was lean for 15 seconds or more (no HO2S switching) - Fuel control
42 (R) System rich - Fuel control
(M) System was rich for 15 seconds or more (no HO2S switching) - Fuel control
43 (R) HO2S sensor not reading (run at 2000 rpm's for 2 minutes and retest - check for HO2S switching)
(M) Was lean at WOT for 3 seconds or more - Fuel control
44 AIR system inoperative - Air Injection
45 AIR not Diverting (AIRD) - Air Injection
Electronic Ignition - coil primary circuit failure - Ignition Systems
46 AIR Bypass (AIRB) not working - Air Injection
Electronic Ignition - primary circuit failure coil 2 - Ignition Systems
47 Low flow unmetered air (check for small vacuum leaks, injector o'rings, gaskets etc.)
E4OD transmission 4x4 switch/circuit problem - Transmissions
48 High flow unmetered air (check for large vacuum leak, inlet hoses etc.)
49 Electronic Ignition - spout signal circuit problem - Ignition Systems
Transmission 1/2 shift problem - Transmissions
51 Engine Coolant Temperature (ECT) sensor signal is/was too high - ECT
52 Power Steering Pressure Switch/circuit open - PSP
(R) Did you turn wheel during test ?
53 Throttle Position sensor too high - TPS
54 Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal high - IAT VAT
55 No or low (under 7.5 V) Key Power to PCM pin 5
56 Vane Air Flow (VAF) or Mass Air Flow (MAF) sensor high - VAF MAF
Transmission Oil Temperature sensor too high - Transmissions
57 Intermittent in Park/Neutral/ Switch or Neutral Pressure switch circuit - PNP or Transmissions
1990 Scorpio - Octane jumper installed (information only code - to inform you if it is installed or not)
58 Idle Tracking Switch (ITS) signal problem ISC
Vane Air Temperature (VAT) sensor out of range or open - VAT
59 AXOD 4/3 circuit fault - Transmissions
3.0L SHO - Low speed fuel pump circuit problem - Power / Fuel Pump Circuits
Transmission 2/3 shift problem - Transmissions
1990 Scorpio - Idle jumper installed (information only code - to inform you if it is installed or not)
61 Engine Coolant Temperature (ECT) sensor is or was too low - ECT
62 AXOD (KOEO only) 3/2 circuit short to ground - Transmissions
AXOD (KOEO AND KOER) 4/3 circuit failure - Transmissions
E4OD excessive converter clutch slippage - Transmissions
63 Throttle Position Sensor (TPS) signal too low TPS
64 Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal low or grounded - IAT VAT
65 Check intermittent HO2S (signal or ground) - Fuel Control
(R) E4OD truck - cycle OD cancel switch after engine ID is received - Transmissions
1984 3.8L ONLY - O, M Battery voltage high (check for electrical system overcharging)
66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
Transmission Oil Temperature (TOT) signal low (possibly grounded) - Transmissions
67 Park/Neutral circuit fault - PNP
Transmission Manual Lever Position (MLP) sensor circuit - Transmissions
(M) Intermittent Park Neutral Position (PNP) sensor fault - PNP
68 Idle Tracking Switch (ITS) circuit (possibly grounded) - ISC
Vane Air Temperature (VAT) sensor out of range or grounded - VAT
3.8L AXOD -Transmission Temperature Switch (TTS) open - Transmissions
Electronic Transmission - Transmission Oil Temperature (TOT) sensor was overheated - Transmissions
69 AXOD transmission (O) 3/2 switch closed (possible short circuit) - Transmissions
AXOD (M) 3/2 switch open (poss short to power) - Transmissions
E4OD 3/4 shift problem - Transmissions
70 (M) 3.8L AXOD - Data link to instrument cluster fault. Service any other EEC codes, erase memory and retest.
If code is still present refer to instrument cluster diagnosis manual.
71 (M) 1.9L TBI, 2.3L TBI, 2.5L TBI - ITS signal was grounded when throttle should have been opening ITS - ISC
ISC motor problem or Idle Tracking Switch (ITS) signal wire shorted to ground - ISC
(M) 1.9L MFI - PCM re-initialized. Possible electrical noise, case ground or intermittent VPWR problem - VPWR Diagnosis
(M) 3.8L AXOD - Data link to instrument cluster fault - See code 70
72 (R) No MAP or MAF change in "goose" test - retest, check for frequency or voltage change - MAP MAF
(M) 1.9L MFI - VPWR circuit to PCM was intermittent - VPWR Diagnosis
(M) 2.3L T/C - PCM re-initialized. Possible electrical noise, case ground or intermittent VPWR problem - VPWR Diagnosis
(M) 3.8L AXOD - Message center data link circuit fault - See code 70
73 (O) Rerun test, if 73 is still output replace TPS
(R) No Throttle Position Sensor (TPS) change in "goose" test. Must get at least 25% throttle rotation - TPS
74 Was brake depressed after engine ID was received ?
Brake On Off (BOO) signal open or short to ground - BOO
75 Brake On Off (BOO) signal shorted to power - BOO
76 Vane Air Flow (VAF) did not respond to "goose" test - VAF
77 System did not receive "goose" test - see TESTS
78 (M) VPWR circuit to PCM was intermittent or the PCM is bad VPWR Diagnosis
79 A/C is on or pin 10 is shorted to power
80 SERIES CODES GENERALLY ARE CIRCUIT PROBLEMS THAT COULD BE WIRING, RELAY OR SOLENOID RELATED.
ONLY ONE OF THE CIRCUITS LISTED UNDER THE CODE IS USED ON EACH VEHICLE. THE FAULT IS IN WHICHEVER SOLENOID OR CIRCUIT IS PRESENT ON THE VEHICLE
81 Boost control solenoid - Solenoids
AIRD solenoid - Solenoids and Air Injection
3.0L SHO - Inlet Air Solenoid - Solenoids
82 2.3L TC - Fan Control wire shorted to ground - A/C and Fan Circuits
AIRB solenoid - Solenoids and Air Injection
3.8L SC - Super Charger Bypass Solenoid - Solenoids
83 High Electro Drive Fan circuit fault - A/C and Fan Circuits
EGR Control solenoid - Solenoids
3.0L SHO - Low Speed Fuel Pump Relay circuit - Power / Fuel Pump Circuits
84 EGR Vacuum Regulator - Solenoids
EGR cutoff solenoid - Solenoids
EGR Vent solenoid - Solenoids
85 2.3L T/C Automatic - 3/4-4/3 Shift solenoid - Transmissions
CANP solenoid (ALL 1989) - Solenoids
(M) 1.9L MFI - System has corrected rich condition - Fuel control
86 2.3L or 2.9L Truck - A4LD 3/4 shift solenoid - Transmissions
(M) 1.9L MFI - System has corrected lean condition - Fuel control
87 (O) Fuel pump circuit fault (check inertia switch) - Power / Fuel Pump Circuits
Vehicles with 2BBL carb - Temperature Compensated Accelerator Pump Solenoid - Solenoids
(M) intermittent in fuel pump primary circuit - Power / Fuel Pump Circuits
NOTE: On some Escorts with automatic seat belts this code is normal IN MEMORY due to the wiring
88 Throttle Kicker Solenoid - Solenoids
Variable Voltage Choke relay circuit fault - VVC
Fan Control circuit fault - A/C and Fan Circuits
A4LD - Converter Clutch Override solenoid - Transmissions
Electronic Ignition - IDM, DPI or spout circuit fault - Ignition Systems
89 A4LD - Converter Clutch Override solenoid - Transmissions
AXOD Torque Converter Control solenoid circuit - Transmissions
Exhaust Heat Control (heat riser) solenoid circuit - Solenoids
90 SERIES FUEL/AIR INJECTION CODES ON VEHICLES WITH DUAL OXYGEN SENSORS REFER TO THE LEFT OR FRONT SENSOR. EXCEPT: 1984-1988 3.8L ENGINES: RIGHT SENSOR
91 (R, M) System running lean - Fuel control
Transmission SS 1 circuit/solenoid problem - Transmissions
92 (R) System running rich - Fuel control
Transmission SS 2 circuit/solenoid problem - Transmissions
93 (O) Throttle linkage binding or bad ISC motor ISC (R) HO2S not reading - Fuel control
Transmission TCC circuit/solenoid problem - Transmissions
94 AIR system inoperative - Air Injection
95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
(R) AIR not Diverting (AIRD) - Air Injection
(M) Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
96 (O) Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
(R) AIR Bypass (AIRB) not working - Air Injection
(M) (Service 87 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
97 E4OD OD cancel light circuit failure - Transmissions
98 (R) Did not pass KOEO yet (Get 11 in KOEO first)
Transmission EPC circuit/solenoid failure - Transmissions
99 (R) ISC needs to learn (Let idle for 2 minutes; Erase memory and retest)
Definitions
ACT Air Charge Temperature Sensor / BP See MAP /
EEC Electronic Engine Control System
ECT Engine Coolant Temperature Sensor
EGR Exhaust Gas Recirculation Valve
-- EVP Valve Position Sensor
EGR / HEGO Heated Exhaust Gas Oxygen Sensor
KOEO Key On Engine Off
KOER Key On Engine Running
MAF Mass Air Flow Sensor
MAP Manifold Abso
DIY stuff
TV cable links not working
FOXLESS!!
1994 Lincoln Mark VIII
DIY stuff
should be good now,, only 2 hours later fixing all the links.  there are a couple dead ones though.
DIY stuff
Lots of great info here. This should be moved to the "greatest hits/tips" section and be made a sticky.
FOXLESS!!
DIY stuff
Quote from: 20thanniver-ls;343551
yup.
DIY stuff
it may just be my pc but several are  not loading.
Photobucket.com  is free also but i see  you already have this site setup to use.
maybe someone else can check the link here in the USA
Thank you for doing this scan!!!
DIY stuff
Some of the pages look blank on the summery page but are there if I click on them.
DIY stuff
no sn-95 t-5 link ;).
I'm glad you do things like this.
DIY stuff
mostly joking.
I've found that a lot of guys didn't want to use any sn-95 t-5's because they think they need to swap input shafts and bellhousings.
its really not that big of a deal, but its really easy to just use the f-150 flywheel or balance the 3.8 one and use an 11" clutch. when I looked into it, Icouldn't find any information or anyone that used one with the 3;8 bell.
