Topic: +/- 40 or, This Winter's Upgrades (Read 9101 times) previous topic - next topic
I'm going to have to fit a trip to indy in this spring and check it out!  Maybe I'll be able to drive the slougar if I get the transmission fixed.
Quote from: CougarSE;355483
If by "fixed" you mean T5 swapped, DO IT!!!!!
And you should make sure its an autoX weekend when you come out, see the car in action :D
Quote from: gumby;355409
Other things that need done in the next two weeks:
  • Finish inner tie rod install [COLOR="red"]DONE[/COLOR][/B]
  • Have 275's mounted on FR500's [COLOR="red"]DONE[/COLOR][/B]
  • Install new ign switch and pigtail [COLOR="red"]Switch DONE[/COLOR][/B]
  • Reinstall center console, and passenger front seat
  • Oil change
  • Get car aligned [COLOR="red"]Scheduled for 26th[/COLOR][/B]
She went for the first drive of the year tonight! After I finished up the inner tie rods, put on the wheels, and took it down off jack stands, I couldnt help myself....tightened the bolts on the drivers seat, slapped the ign. switch in it and pulled it out of the garage :hick:
brake check, yup
steering check, yup
cruise around the block, of course!
light the tires up in a second gear roll? HELL YES!
mid 50's temps are very kind to turbo cars :burnout:
I was gonna get a pic of the car with the rear 275's/FR500's, but it got a bit dark before I got everything cleaned up. I'm not a fan b/c of the lack of lip on FR500's, but they are the same offset as what my Desmonds will be once I get the proper pieces, so I know how my wheel/tire combo will fit at least. They will get me thru...
grabbed a couple pics just now.
I am super happy with the new rear offset, ride height is unchanged, but overall stance is a bit tougher with the extra width out back. I just do not like black wheels....I cannot wait for the correct wheel parts to get here!
Oh, I brought home a pair of toe plates from work too. Toe was way out after replacing the inners, and since my alignment appointment isn't till the 26th, I wanted to get it at least close enough to drive around.
Tomorrow I'll bring home a set of scales and scale the car. Hasn't been done in nearly three years now. I have removed/relocated weight and changed wheels/widths, multiple times, so I need to at least check my cross weights again.
Looking very good...man that baby is low.  I agree with you on black wheels, not my thing.  I do really like the look of the FR500's though!
I've been looking at that picture (front/side) trying to figure out WHY it looked like you had some skinny little tire on the back and just now figured out it was your exhause pipe and not your driveway that I was seeing, ROFL
You're not the only one; Shawn asked me the same thing!
Moment of Tr00f!!!!
Last time this car was on scales was right after I got it together in 2008. It was 3199 w/half tank of fuel and no driver. 51.8%F/48.2%R and after a minor adjustment, 50/50 cross weight.
Today the car has a full tank of fuel and weighs.........[SIZE="3"]3199lbs!!![/SIZE][/B] :rollin:
I was a lil surprised to see the exact same number again, but using 6.25lbs/gal for gasoline shows I have taken ~56lbs out of the car in the last three years. What I really did like to see was that not only did I remove weight, but I managed to get it out of the proper end of the car. The car now has 50/50 distribution both front to rear, AND cross weight! w00t!
Reply #39
gumby, that car's looking awesome. Just think how awesome it's going to look when it crosses the line behind my '97 :evilgrin:
*edit - that's cool that the car schematic on the scales looks like an 87/8 t-bird, too!
Reply #40
gumby, I really like your car.
It is amazing that your car is balanced front to back.  What exactly have you done to remove weight from the front of the car?
What do you think a stock TC front/rear balance is?
Reply #41
Tubular Kmember, control arms, and coilovers are the biggest components that removed weight on the nose. Relocated battery, lightened front bumper, custom upper intake, and ditchin the TEVESII all helped as well.
The IRS adds a few pounds out back. Its a trade off, sprung vs. unsprung weight, but it does contribute to balance as well with the added weight being low and at the rear.
Reply #42
  • Reinstall center console, and passenger front seat [COLOR="red"]DONE[/COLOR]
  • Oil change [COLOR="red"]DONE[/COLOR]
  • Get car aligned [COLOR="red"]DONE[/COLOR]
List is done along with a lil polish on the roof and hood. Cleaned the windows. Sittin on GO, now its gonna snow tonight. :punchballs:
Reply #43
I just now saw the post on the weight balance.  Nice!
Reply #44
Quite a machine Gumby. Good work, mate.
