Topic: auto lock (Read 2078 times) previous topic - next topic
auto lock
Anyone remember the code to set the auto door locks (when put into gear)? :hick:
auto lock
Thank You Sir !!!!
auto lock
The default setting is on. If it doesn't lock the doors after you shift through reverse then something is wrong. The most common thing I've found is that the connector under the driver's seat sensor comes off. Just hook it back up and it should work again :)
auto lock
Quote from: thunderjet302;342731
No sir , default is off according to my owners manual , if the battery is disconnected the system has to be turned back on ...... page 132 in the 1988 owners manual
auto lock
Quote from: hypostang;342751
I swear it says the default is on. I've disconnected my battery countless times over the years and I've never had to put in a code to turn the autolock on.
auto lock
I'm just reading what my manual says
My auto lock is not on in my car and has never been:D
auto lock
Sure enough my manual says the same thing. My car must be a freak.
auto lock
Quote from: thunderjet302;342822
It's because it doesn't have a blue oval on it....lol
auto lock
Thanks Guys...it works, it was off though because i had to replace my battery.
auto lock
mine has never had to be turned on ever,, and i to have had the battery unhooked.
