Topic: v6 to v8 (Read 6194 times) previous topic - next topic
v6 to v8
Ok.  Repinning the connector will be a major pita with the harness in the car.  It really wasn't all that hard.  I have an EVTM somewhere and Jrcassity has scans of his somewhere.
See if you can PM him.
v6 to v8
Ok can any one help. I see that the black plug for the harness on the driver side has a diff shape that the other and a guy has one he said its for an 87 but it looks just like an 88. I have a pic of my 87. And I have pics of the one the guy said is an 87 v8 harness
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
v6 to v8
Pics?  I'm confused about which connector you are talking about.
v6 to v8
I'm talking about the black one ull see when I get the pic up
:birdsmily:
v6 to v8
:birdsmily:
v6 to v8
I have that black plug on my '87 harness that's in my Turbo Coupe, had to rebuild the female connector and wire it into the body harness... It should have a green/red wire in it that feeds power to the EEC relay, F/P relay, coil etc... Power to that one connection is all that's necessary to run the engine, of course this assumes the fuel pump harness is still connected to the EEC harness...
I've seen the gray plug in the '88 cars, maybe the late '87 had the same setup???
v6 to v8
any one have a wire diagram for it and could fill me in on what i can do then. i have 2 88 v8 and 1 87 v6 harness. i dont have a problem cuting the end off and rewireing it i just dont know what wire is for what. the fuel pump is useing the stock setup wires and all.
:birdsmily:
v6 to v8
My 88 has the grey harness I believe.
v6 to v8
Ya as my 88 that I took the motor out of both plugs look like the gray one. But the 87 the black is not the same. So I need one for an 87 or need to know what colors go to what so I can wire the 88 harness to the 87s mane harness
:birdsmily:
v6 to v8
any one have a wiring diargam of the plugs that they are willing to post?
:birdsmily:
v6 to v8
ok guy i'm new here and i'm in need of finding 302 motor mount brackets for 93 xr7,,, car had 3.8, swapping out for a 69 mustanf 302 with carb,,, but i need the mount brackets,,,, can someone give me a hit to where to find,  other that salvage yards. here in stl hard to find a cougar with 5.0 or thunderbird all have 3.8 or 4.6
v6 to v8
you might get more help if u start your own thread
:birdsmily:
v6 to v8
did you find out if they were 87s?
Quote from: ThunderbirdSport302;343567
I might know where one, and maybe even 2 '87 5.0 harnesses are...I just have to go ask if I can look at the cars to see if they are truly '87's, and what shape the engine wiring is in. I need some other small pieces for something of mine, so maybe I can get out there before work one day this week and see. Not sure if they let folks wander around anymore...
:birdsmily:
v6 to v8
Ok so today its runing but I have no speedo numbers no power locks no clock and no lights when I open the door or when I. Turn the dimer switch. Dose anyone know. I swaped the v6 dash harness to a v8 one and still won't work right
:birdsmily:
v6 to v8
Check the fuses really close. I had the same issues, but because I had a grounded harness. I had installed a fastener into the body and it went through a wire and grounded it to the body, which caused blown fuses. After I figured out what I did with a little help from a friend here (Thanks Jerry), I fixed the problem, everything works, and no issues. Report back what you find. One way or another, we'll all get your problem figured out.
