Topic: R.i.p. (Read 8238 times) previous topic - next topic
R.i.p.
What happened with the douchebag that caused it all?
R.i.p.
Quote from: bhazard;342107
Drove away in his nice shiny 300.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
R.i.p.
Quote from: Haystack;342058
I doubt you bent the frame. Do both your doors open up fine after taking off the fenders? At least your bumper bracket didn't just break off at the weld. It looks similar to what I did, just on the other side of the car. The only thing that isn't sitting right on my car is the bottom of the radiator support. Everything else was just pull off and put back on. After I re-welded the bumper bracket and bent it back in place, and pulled the radiator support bottom out alittle bit (I actually pulled it alittle bit too far, and now I can't bend it back, Just wanted the car on the road.) and swapped the cougar front end on, and good as new. I still have alittle bit of gap between the hood and the header panel, but that was because the cougar front end I swapped on. The guy who had it before me wrecked it and fiberglass the front end to the fenders, so I only had four good bolt holes, and they didn't quite line up from how he glued it back together. I did not bend up top where the fender bolts to either though.
X
Here's a pic of the drivers side rail, supposed to be straight.
R.i.p.
Ironic that it was a Cobalt.... It must have been "cursed" too!
2017 Subaru Outback
2007 Lincoln MKZ
1990 Ford F250 / Banks turbo diesel
R.i.p.
Quote from: BadTriumph;342111
Yea, the wife and I thought the same thing...lol. Watch out for Cobalts!!!!!!!
R.i.p.
Quote from: cougarman;342112
I must have missed that inside joke- did you have dealings with another cobalt?
CoogarXR : 1985 Cougar XR-7
R.i.p.
Herb owns a Cobalt and he calls it the "cursed" car.  Check out his signature...
R.i.p.
It's probably still fixable but more pricey.....
R.i.p.
That'll buff out.  I would start with the more aggressive rubbing compound though.
R.i.p.
Reply #39
Quote from: cougarman;342108
You're kidding....nobody knows who he is or anything?
R.i.p.
Reply #40
R.i.p.
Reply #41
Nope.:beatyoass:
R.i.p.
Reply #42
I didn't notice the frame rail under the battery. Mine stayed straight. let us know what you end up doing.
R.i.p.
Reply #43
Sorry to see this happen to you guys. I lost a t bird and a cougar as well and both times sucked.
R.i.p.
Reply #44
Quote from: SirChirpAlot;342214
Thanks, yea really sucks. :punchballs:
