Topic: R.i.p. (Read 8167 times) previous topic - next topic
R.i.p.
I feel your pain, as i for one can most certainly relate.  I hope you can bring her back from the brink.....best of luck!
R.i.p.
we can fix that !!!!  I just got in a donor car we can cut the apr0n and core support from, got everything else in stock to put her back together. let m eknow if interested Herb,
John
R.i.p.
Quote from: RunninWild;341980
how did it happen exactly?
Well, I was following my buddy to school. We just had taken off from a stoplight when some kid in a Chrysler 300 goes blowing by us on the side of the road. He got between us, and then passed my buddy and the car in front of him. We were slowing down to turn into the school, when the 300 just jamms his brakes on and turns in, causing the guy behind him to stop short. My buddy locked his brakes on his Suburban and veere to the right, causing me to jam on my brakes. I had to swerve to the left slightly to miss him, and still sliding, seen the other car in the middle of the road. Had about a split second to either slam the car in front, hit my buddy or swerve to the left to miss them both. Unfortunately there was a Cobalt coming in the other lane, and through a series of swerving left and right we met in the middle. One bright spot was the Cobalt was dead, but I drove the Tbird into the Autoshop at school under it's own power.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
R.i.p.
Quote from: hcor;341990
PM sent.
R.i.p.
So you hit the cobalt head-on?
CoogarXR : 1985 Cougar XR-7
R.i.p.
Sorry to see this happened but like everyone else I'm glad to see you're okay. Hopefully you can save the ol girl.
R.i.p.
Wow.  I hope you can rebuild her.  It sounds like she's not dead yet!
1990 Mark VII LSC
1990 Mark VII LSC SE
1969 Cougar 351W
R.i.p.
That's a major bummer! :(
1987 TC
R.i.p.
Good to see you posting about it, although the subject itself hurts to read...
With that said...maybe it'll turn into a labor of love.
I think I might have a few little pieces that I don't/won't need...if so, I'll donate 'em for shipping if you decide to rebuild. :cool::welder:
R.i.p.
Quote from: CoogarXR;342007
Hit the Cobalt right on the drivers side front wheel, as we both tried to turn away. The impact drove the Cobalt back and sideways.
R.i.p.
Quote from: ThunderbirdSport302;342044
Thanks appreciate it.
R.i.p.
I doubt you bent the frame. Do both your doors open up fine after taking off the fenders? At least your bumper bracket didn't just break off at the weld. It looks similar to what I did, just on the other side of the car. The only thing that isn't sitting right on my car is the bottom of the radiator support. Everything else was just pull off and put back on. After I re-welded the bumper bracket and bent it back in place, and pulled the radiator support bottom out alittle bit (I actually pulled it alittle bit too far, and now I can't bend it back, Just wanted the car on the road.) and swapped the cougar front end on, and good as new. I still have alittle bit of gap between the hood and the header panel, but that was because the cougar front end I swapped on. The guy who had it before me wrecked it and fiberglass the front end to the fenders, so I only had four good bolt holes, and they didn't quite line up from how he glued it back together. I did not bend up top where the fender bolts to either though.
R.i.p.
Gentlemen, we can rebuild her. Better...Stronger...Faster....(ooo-weeee-deee-dooooooo.....)
Glad you are okay.
R.i.p.
ironically it happened right out front of the school, where i'm taking autobody repair
class project car!
