Topic: bad alt! 2.3T (Read 1892 times) previous topic - next topic
bad alt! 2.3T
does anybody know if they make G3 alt. kits for the 2.3T? i read in one of the mustang mags i get on a kit for fox 5.0's so it got me curious if the 2.3T have one too.
bad alt! 2.3T
Kit? What's a kit?
Buy one, wire it up, done.
3G alt swaps have been covered on here a couple times.  Look it up.
bad alt! 2.3T
yeah, they make kits for fox 5.0s, it comes with a bracket, the alt and a pigtail i believe. ive only been able to find threads on doing the G3 swap on 5.0s, not 2.3 on here.
are the plug ins the same or will i need to go to the s yard and find one?
bad alt! 2.3T
Look closer.
http://www.foxtbirdcougarforums.com/showthread.php?t=13641
You don't need a kit.  You need an alternator and a pigtail.
bad alt! 2.3T
Its a sticky by jcassidy
87 TC
bad alt! 2.3T
The 2.3 diagrams look different from what i have.. They have 2 plugs. one with 3 wires and the other with one. I have 2 plugs but both of them have 3 wires.
bad alt! 2.3T
alright, i figured stuff out. Thanks for the help Chuck W
