Topic: Spedo (Read 3543 times) previous topic - next topic
Spedo
Hi I've swapped from auto to stick and 2.3 to 5.8 carbed. I lost the computer and with it the speedo. Can I use a mustang spedo and cable and a drive in the tranny I know I can get the drive and cable I'm looking for a good fit in the dash?  While I'm here can I get the factory tach to work?
Thanks  :burnout:
Spedo
Are you going with a T5 for the trans...just get the driven gear for the wheel/tire combo in the T5 application, stick it in, done deal.
The stang cluster won't work in a Bird/Cougar dash...as for the tach, I put an '88 Sport (V8) cluster in an '88 3.8 car...added some wire to the tach input on the cluster, and ran it up to the coil...for some odd-ass reason, the tach registered correctly although it was for the 5.0...
Anyway, the speedo issue is really easy, use the wire you have, just get the correct part from a T5 (or whatever trans you use, be it T5, T45, T56 etc)
There's a chart HERE that will help you pick the right color/teeth per wheel/tire size you run.
Spedo
Quote from: ThunderbirdSport302;341002
  I'm using a t5 till I get the loot for a Tremec I plugged the tranny in with the factory plug and no speedo I was told that since I took out the speed density computer Id need to go to a cable driven speedo
Spedo
I can't say if the lack of an EEC will affect the electro-speedo or not...as far as Mustang clusters go, the rather large aftermarket for 'Stangs has tempted me to swap in a 94+ Stang dash...but, not sure of they're cable or electric speedo (read; too tired/lazy/sleep to search right now lol)
Maybe someone else will chime in about the no eec/speedo quandary..
Spedo
I've got a 94 stang that's rusted to death. I'm gonna grab the parts for a five lug swap the cluster is out I'll look tomorrow after work I've got to go to school in  a hour. I'm currently  scratching my head doing a 3 g upgrade. The pic for the 2.3 diagram wont print thank god for lap tops
Spedo
Finished 3G upgrade just in time found a few melted connections.. ThunderbirdSport302 Ill look tomorrow at the cluster
Spedo
Congrats on finishing the 3G and not having a major wiring meltdown  ,,, just out of curiosity  where in Worcester are you ?
Spedo
they call it Quinsig village its over by rt 20 on the auburn millbury line behind holy cross college
Spedo
I know exactly where it is
  I worked on Quinsigamond ave for 11 years  at Quinsig auto /Christie Thompson  now Fisher auto parts  :)
 I grew up in Greendale
Spedo
My buddy Wayne runs that store now they closed the Framingham store and he went there they actually moved next door and the old store is warehouse
Spedo
When you did your swap did you lose your factory amp gauge
Spedo
Wayne Wallace Winch , he and I were very good friends when I lived up there.  Tell him Daryl said Hello next time you speak to him ,  he will know who I am
 And My amp gauge works just like factory after my 3g swap
Spedo
 I lost the gauge?  I'll have to go back in.
And I did not know about the Wallace in the moniker That would make him WWW.
Spedo
I believe the green wire is the gauge feed , but dont quote me on that .
 And yup he was the original WWW  ..lol
Spedo
Ill check the connection after work tomorrow
