Topic: Another digital dash question. (Read 2634 times) previous topic - next topic
Ever since ive owned the car the far right side of my dash hasnt worked, i didnt even know what it would show, i guess it is current MPG and average too. I just assumed a bulb had went out and i just needed to replace it. well about three months ago I was turning into my drive and when i hit the blinker all of my dash nights kicked off, and wouldnt work unless my headlights were off. then the speedo went out and the far right one came on, all the while only when the headlights were off. long story short, the only side working is my RPM side when i dont have my lights on and when the head lights are on i cant see my speed or anything. i guess there is a short somewhere or something but should i just tear into it or is there any place that i should look first? I can hit it with a flash light and see my speed and everything its all working but its not illuminated.
Id replace all the bulbs (just so you KNOW they arent burnt) And while you have it out check the two connectors that the cluster plugs into. When I took mine out to try LED's, the far right side with the MPG computer wouldnt come on. After cleaning the pins on both sides of the connector, it worked perfectly fine.
Just a thought, the involvement with your headlights makes it sound like a bigger deal than what I'm thinking lol
1988 T-Bird LX- Awaiting HO build, Monster "Eat My Shift" AOD rated 550Hp. BBK ceramic shorties, Jegs mustang (catless) H-Pipe. mustang catback modified axle back for tbird, 94 17" Cobra wheels, 98 'Stang GT 8.8 Traction-lock
Make sure your headlight switch thumbwheel is not all the way down also.... if it is your dash will go out  when the headlights are on
Does anyone have pictures of what I'm about to get into tomorrow night? Also, kinda wanna install a Autoguage tach tonight for as long as I don't have my dash lights, the white wire is the one that connects to the dash lights but where does it hook in?
What exactly are you needing pictures of ?
Well I haven't looked too much into it but I was thinking bulb and connection location... finding out how to take the digital cluster out shouldn't be hard thanks to coolcats. Lol
i have a couple extra clusters ill snap a pic or two for ya
I hope these help
The important thing to remember is if you have a column shifter
you have to take the column trim off and undo the PRNDL connection in order to take the cluster out  , I dont have any pics of that part but once you get the column cover off its pretty self explanatory
Its a white plastic collar that has one screw in it
Did you check to make sure your dash dimmer is not all the way down
before you start to take it apart ?
Lol I work at O'Reilly and those clusters are expensive! Probably be easier to find one in a boneyard if I ever need one. Oh yeah and a friend asked how hard it'd be to convert it to buttstuffog. I didn't know where to start... how hard would it be?
Yeah its all the way up, and when it first started this I gave the screen a good love tap and it came on for a day....
If you have an EVTM ..not too hard but you would lose all the trip/ fuel economy info .
You would have to get an buttstuffog cluster from a V8 sport or it gets a little more difficult because you have to modify the non V8 tach
I thought about swapping mine but I got it working properly now and I like it ;)
And as an added note just last night I pulled my cluster out again to do 199 mph mod and it was 1 hour start to finish soldering and all :D
 My point is its not hard to take the cluster out
Lol I should do that and fix my PRNthingy ma-bob cuz it says I' in m in OD when I'm in 1. Haha. And Park is reverse.
Go for it , let us know how you make out
