Topic: What Can I use in the 88TC from a 96 GT Stang (Read 1311 times) previous topic - next topic
I have a line on an 96 mustang gt and would like to know If I can used the rearend and t5 in my TC Oh ya I would also be using the front spendals ?sp and roters for the 5 lug swap. should everything bolt in???
87 TC
Oh ya I currently have CHE upper and lower both adjustables with mach springs and strange 10way adjustables in the rear I also have the mach springs and strange adjustables in the front. But second gear is rappidly going out and I have a bad vibration comming from the rearend on the current set up.
87 TC
You can use the rear end for sure.  The front spindles, 5 lug brakes will work also.  You'll want to run the SN95 master cylinder for the best pedal effort/feel.
Unfortunately, the T5 won't work - as the input shaft is too long on the SN95 cars.
Everything else can be fabricated up.  Even the interior could be swapped if you wanted.
Good luck!
The '96 spindles are a big NO for your '88.
'94/'95 only on those..read THIS for the appropriate info and links to explain.
As mentioned above, the rear is a direct swap, or if it's the 7.5 (V6 car only) you can pull the axles, brakes, etc and swap onto your 8.8 .
Do grab the front rotors, calipers and struts if you can, then all you need is the '94-'95 spindles...good to go.
