Topic: header gaskets (Read 1923 times) previous topic - next topic
header gaskets
My BBK 1515 headers have already developed an exhaust leak after only a few thousand miles of use.
The gaskets that came with the headers were pretty questionable looking but dumb a$$ me used them anyway.
I think I need to go copper...any brands you guys recommend?
header gaskets
MR gasket from the part store.  cant remember the number but Oreilly's usually stocks them.  I use them on everything just make sure you get them tight heat cycle then tighten again.
header gaskets
Fel-Pro 1415. Retorque after heating them up and good to go. Have them on my BBK's and no issues.
Darren
header gaskets
Thanks guys.  I retorqued these a couple of different times but they still leaked (the ones that came with the headers were pretty junky).  I might go to NAPA and tell them to give me their best gasket...
header gaskets
Quote from: Aerocoupe;339899
Fel-Pro 1415. Retorque after hearing them up and good to go. Have them on my BBK's and no issues.
Darren
This is def the way to go-I have these on my BBK's.
header gaskets
Percys. They are re-usable,and I've had them for quite some time and two engines.
header gaskets
when i put the new engine in last fall, the ones from oriellys gasket kit worked fine. Although i think they are fel-pro.i dont remember.
Remember, if the women dont find you handsome, they should at least find you handy.
When all else fails, get a bigger hammer.
Chris
 93 cat rebuilt 3.8
header gaskets
I will check on the Fel-Pro's.
Vinnie I don't guess I've ever heard of Percy's before.  The reusable aspect of it sounds interesting, however.
header gaskets
Check into them.
header gaskets
Personally,I always use the Permatex Hi-Temp Copper RTV. I apply it to the header (or cast exhaust manifold), assemble it and tighten the bolts finger tight, wait 24hrs for it to cure then torque to spec. So far, I've had zero failures on over a dozen installs. There are a lot of racers using the same trick.
header gaskets
Quote from: QUICKSHIFT;339954
lol,, use the same stuff on my wood stove holding the fiberglass rope on the door seal.  that stuff does do good around heat.
GE makes a better verision and thats what i use.
