Topic: Check out this 87-88 grille insert (Read 2361 times) previous topic - next topic
I have never seen anything like this before. I think it was intended for the 87 and 88's that had that grille opening found in Tbirds with 3.8l V6 or 5.0l V8. Any insight?...http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4548625978&category=42611
Re: Check out this 87-88 grille insert
Looks like they meant to do a TC-ish knock-off with it.
It's an interesting piece, but I wouldn't use it. With my '88, I want to eliminate all the crossbars in the middle, vertical and horizontal, and just leave the exterior frame with some blacked-out wire mesh behind it. Cool air is more important to me than a smoothed-out front end.
I can make you one. let me know
I've got a 5.0l in my TC and have non issues with cooling what so ever.
If you have the airdam still on your car it will direct air into the radiator while driving.
i have a TC nose on my 3.8L, with the base bumper cover, no problems
as long as the airdam is good, theres no problems with cooling
-coul this be aftermkt?? if you notice the emblem does not fit the recess very well....
Quote from: Tbird232ci
if i put both the bottom and upper portion of the bumper from on my 87 sport will it affect the cooling of the engine? i'm taking the bumper and hood off of one for use on that.
well...if itll cool a 2.3L turbo...itll cool your 5.0...
hey anything to watch out for when swapping the fronts?
Basially a swap and go.
