Topic: Cadillac Northstar injectors... (Read 2933 times) previous topic - next topic
What size are the Cadillac Northstar engine injectors? Anyone have any idea?
I think I have a set, Ill see if I can find them and chase down the numbers for you
After a search, the only info I found, was 23.5, and that was a maybe.
I heard they were 24# injectors,but just don't know.
Should be an 8 digit GM part# on them SOMEWHERE.  Call up a dealer with them and see if they can answer the question
I may just have to do that.Thanks.
One set I have are 19's.I'll check the other set tomorrow.I'm guessing the same thing there as well.I found a flow chart for them.
The size is dependent on fuel pressure, AFAIK each mfgr uses different pressures...
Thanks Tom. I'm going to check them against what I use on the car now with this chart......
http://users.erols.com/srweiss/tableifc.htm
Dayum, that chart will keep you busy...
Quote from: TurboCoupe50;338310
LOL...I agree.There are a LOT of injectors out there apparently.I've got a second set of Cadillac injectors I'm going to check out. I need a couple of sets of 24's.I'll find some,I always do.....just a matter of when.
Quote from: vinnietbird;338312
4.6L 32V Mark VIIIs and Continentals are a good source of 24lb injectors. Also 460 EFI trucks have 24s.
I'm still looking for them.There just aren't any of those cars around here right now.Usually they don't charge me for injectors,that's why I don't want to buy any from Ebay or wherever.I figure I'll be patient an some will show up eventually.
Quote from: vinnietbird;338412
.Usually they don't charge me for injectors.
Those fit real nicely in the pockets or tool bag.  Ooops did I say that!:D:D
Mike
Yards around here are up to $6 per injector. Needless to say, unless I come across some 35#
browntop injectors or bigger, I don't bother. Just isn't worth it. I've passed up quite a few 32valve 4.6's.
