Topic: 87 TC Rear Brake Line(s) (Read 1257 times) previous topic - next topic
I swapped an 8.8 differential from an '87 TC into my '85 TC a few years back. I recently developed a leak in the rubber brake line (hose?) that goes from the steel line to the Caliper. Checking with NAPA, they do not show this rubber line as available...Is this a Ford only part, or, worse, will I haveto have a custom hose made..?
someone correct me if i'm wrong, but aren't the ends the same as the front caliper lines on an 80-96 F-series? i know i used them on my 88 when i had a line rupture
Autozoo has them.  They look to be special order though.  Are these what you were looking for?
RockAuto or someone online might have them in stock.
Oreilly shows them also , bh253590, and bh253600
