Topic: Tranny Fluid change (Read 1605 times) previous topic - next topic
Tranny Fluid change
Gonna chnge the tranny fluid/filter in my LSC this weekend, and was wondering what fluid I should use. I know this has been talked about before, I did a search and read up a little and am now kinda torn between the Mercon V and the Type F. I had used Mercon V when I had my MN-12, didn't have any problems with shifting or slippage afterwards but that was a different tranny.
FOXLESS!!
1994 Lincoln Mark VIII
Tranny Fluid change
Use mercron. You can add alittle bit of type f, but I would not run it soley.
Tranny Fluid change
I'm not sure if the AOD should be using Mercon V. I seem to remember using Mercon III in my AOD and Mercon V in my 4R70W.
Tranny Fluid change
Quote from: cougarcragar;337089
Thats pretty much what I was wondering. I used it in my 4R70W but never have in an AOD. I *think* I have always used the Dexron III/Mercon in my previous (pretty sure, anyway) and don't ever remember having a problem, but didn't know if there was any benefit of using another type.
FOXLESS!!
Tranny Fluid change
This came up before with a lot of debate. I had asked a few trans guys and got the same answer that mercron V is backwards compatible with older mercron fluids.
Tranny Fluid change
Run the Dex/Merc if you can find it -- Mercon V if you can't.
Tranny Fluid change
The DexIII/Mercon is available here. Thanks guys
FOXLESS!!
