Topic: bbk longtubes with chuck w mounts (Read 935 times) previous topic - next topic
I might be trading a fox mustang for a 87 Thunderbird 5.0 and wanted to put my bbk longtubes on the tbird. I've messed with mustangs for awhile and I thought Thunderbirds were basically the same until I saw the motor mounts. I was wondering if I got a set of chuckw motor mounts if I could run the longtubes, or would I have to swap over to a mustang k member.
Is it an column shift or floor shift car?
It's a column shift right now but I'm probably going to put my c4 out of my mustang in so then it would be a floor
I have bbk longtubes on my cougar with 408w,tremec, and chuck mounts. I did have to switch to an aftermarket steering shaft because the stock one hit the header
