Topic: Cold air intake 5.o (Read 7430 times) previous topic - next topic
Cold air intake 5.o
What all would i have to do in prep for a cold air intake on my 5.o.
Re: Cold air intake 5.o
Do you want to get one like I have?
Prep work that needs to be done is to take all the black plastic  that's inside the fender out and obviously remove your original air box and air inlet tube. Nothing really difficult about it.
so no maf or any sensor replacements? and yes that looks awesome where did you get the tubing and stuff. Local auto zone or murrays, thank you
you can buy em off of ebay pretty  cheap, but the only problem is they arnt for non-MAF cars, at that point, you can just stick a MAF in there, and not have if function
I did the mass air conversion on my car so I got the kit that was made for a mass air car. They have the kit for speed density set ups as well. If you left your car speed density and put the speed density kit in, it would be a piece of cake. No sensors or anything like that need to change.
Mine is a MAC that I bought from Speed Unlimited
For some reason though the when you click on the MAC, K&N, and March kits nothing comes up. Autozone sometimes carries the K&N kits but they are way more expensive and they don't look as cool as the MAC's (IMO). BBK makes them as well and you can get them also from Summit or Jeg's.
So here's what you want:
 for speed density - - get one for an 86 to 88 mustang
 for mass air - - - - - get one for an 89 to 93 mustang
You also have your choice if you want a fender mounted filter or not.
Fender Mount (what I have)
Non-Fender Mount
Here's the pic of the fender mounted one for speed density cars.
Ok thanks very much on clearing that up. Victory picture....
(is there any hp advantage to the mass air conversion?)
Like i said not much of a victory but it was for me that was a pain coming out... Infact i tried retreiving this about a year ago and i am now very happy its out
Good work. Mine was a bit of a pain to come out. I actually broke my curb light in the process(woops :rolleyes: ). The mass air conversion should be used if you have an HO setup.
Quote from Cool Cats tech on maf conversion
"For Converted or Transplanted 5.0 HO Speed Density Cougars
This section is for converted or transplanted 1987-88 HO 5.0 motors ONLY. It is not intended for the stock Cougar/Thunderbird 5.0 motor. Any attempt to convert a stock non-HO motor to mass air can result in serious damage to the engine."
If you had an HO, the maf conversion would allow you to make as many modifications as you wanted. So it doesn't give you more horsepower, it just reads the air better allowing for major mods. The mods you do is what gives you more power.
Ahh thank you for your patience i was stumbling into this pretty clueless. and again thanks for clearing that up
No problemo :)
hey do them pipes soak up alot of heat from the headers? I was going to replace my rubber one from the ma meter to the tb... was wondering how hot the tube got
Just a little warm, but what is under the hood that won't gain a little heat. It's far enough away from the headers that it doesn't get hot.
mines still cool to the touch, at the very most it gets slightly warm. and if i ever end up getting header wrap, its probley going to be actualy cold air intake lol.
