Topic: Figured it out!! (Read 2597 times) previous topic - next topic
Figured it out!!
I went out this morning on my way to work.. Started it up and went to put it in drive and the shifter dropped right to the bottom... The linkage came off, the bushing that holds it in broke in half. The Advance Auto said they don't have that part... Anyone have one or know where I can get it.. Its the first linkage I would imagine the one connected from the shifter..
:ford::oldcougar::mercury:
Figured it out!!
I'd ask the Ford dealer.  You could probably fabricate a new linkage pretty easily if it came to it.
Figured it out!!
I found it... Dealer around here had some... $4 and change and a PITA to change...
I may pick up another for a spare only 2 dealers in the area had any stock..
Figured it out!!
Is this the column shifter bushing for the z-shaft between the frame and engine brackets?  My shifter is extra sloppy because of it missing some sort of bushing on the end of that z-shaft.
Figured it out!!
The HELP! brand at the autostores sells a universal-type kit that has all kinds of those bushings in there, I used them on my 20th when I took my linkage apart. Very aggravating to change.
FOXLESS!!
1994 Lincoln Mark VIII
Figured it out!!
The bushing I had to replace was in this picture (not of my car).. NOT the one with the green arrow but the other one....
Not too bad of a change but word to the wise chock the wheels when parked up on ramps and fiddling with the lever of the transmission (ask me how I know)...
Figured it out!!
Quote from: cougar1car;338382
ROLL OUT ROLL OUT hahahah
Figured it out!!
Quote from: turbo_88_XR7;338384
It's amazing how fast you move with 3500lbs about to roll down on you!! :burnout:
Figured it out!!
Apparently you moved fast enough....you're posting this after the fact lol.
Safety first ;):bowdown:
Figured it out!!
Quote from: ThunderbirdSport302;338407
Very true... I pushed the car back on the ramps with my expedition and left it up against it behind it. No more rolling back after that...
Figured it out!!
That's why you should have put it on jack stands;)
Figured it out!!
Quote from: thunderjet302;338522
I know I should have I thought about it but impatient me said it will only take a few minutes to fix.... Also I doubt the jack stands would of had a firm stable platform on the grass I was doing it on either....( don't have a driveway)
Figured it out!!
Yeah concrete helps;)
