Topic: speedometer cable (Read 1263 times) previous topic - next topic
speedometer cable
hi
does anyone know how long a speedometer cable is for a 1984 mercury cougar? they have several sizes one is 72 inches long one is 81 incheslong and then they have one that is like 121 inches long that says cut to fit. im going to replace the cable as the needle bounces around when i hit bumps and it is very jittery when taking off. im hoping this will cure the problems.
thanks
eddie
eddie
my rides well some of them work:hick:
1995 towncar in black 246 K non running
1989 continental 110K waiting for a part
1984 cougar head gaskets done almost ready!
Yikes the daily ride ...1998 chevy lumina:hick:
speedometer cable
When in doubt take the old one off and take it with you. If your are ordering it that will make sure you have the right one. If your outer part is in good shape you can just get the cut to fit and slide that in the old outer part. Make sure you clean and lube the inside where the cable goes. From my experience that floppy speedo if from the cable getting weak and bouncing like a spring.
Stuckman
