Topic: Quick Question (Read 1817 times) previous topic - next topic
Quick Question
The wire that goes from the car to the antenna is disconected at the antena.. im a looser, and lazy, so i put a wire in the cable that coneect to the antena and ran it up (on the ourside of the car) straight to the antenna. Any quick way just to put it back in the antenna, the only way i cous see you had to pop the door and front pannel off, and im jsut too lazy for that lol.
Thanx sorry for the punctuation.
Re: Quick Question
i guess you said it all so any suggestions would be useless.
but if you would like,,
remove the chrome cover on the fender
remove the two phillups screws
fish out the other end with a wire or coat hanger and pull the antenna wire up through.
connect it back.
or........
remove the fender and hook it back up
nuts on header panel and bumper cover
fender well skirt phillups screws
bolt under car just forward of door
bolt through upper pass door henge
bolts along the engine bay
one or two bolts hidden up near the windshield.
Re: Quick Question
Thank you. Yesterday i couldnt get the cover off, but after you said it was possible, I was a little more forcefull, it came off with no problem. Thank you verry much and sorry for the stupid question.
Re: Quick Question
i was just pulling your chain a bit cause you seemed like this was gonna be an impossible thing to do.  it was'nt a stupid question after all.
