Topic: what size rear tires to correct speedometer... (Read 1283 times) previous topic - next topic
I have 17" Rims, 3.55 gears, and a 22 tooth speedily gear. Anyone know the equation to get the speedo as close to accurate as possible using tire sizes?  Wanna get it close enough so the cruise control will work properly.
well then you just need to keep the same size overall OD of the stock tire
so if you had a 225/60/15 the od would be..25.6 inches
so for a 17 you would have to run a 245/45/17 and that is a OD of 25.7
you can play around with tire sizes and gears here..http://www.accuautoparts.com/calculatorfin.jsp
 the crusie is vac operated, so the tire size will not matter, but it will mess with your speedo
Speedo driven (the one on the end of the speedo cable to transmission adapter) and drive (the one on the output shaft of the transmission) gear calculator:
http://www.sccoa.com/faq/speedgr.html
Darren
