Topic: Foglights question (Read 1817 times) previous topic - next topic
Foglights question
I have a 96 cougarand i am thinking about installing some foglights on the front end to help with visibility at night and during rain and shiznit.  The stock headlights have long since frosted over and this is reall a problem sometimes.  does anyone have any suggestions as to what foglights i can get.
By the way, i'm too cheap to buy the $150 glass headlight replacement.
Re: Foglights question
Well if you did some seaching you would find that you could fix your current headlights with some extra fine steel wool and some tire wet or metal polish. Then I would put some fog lights on there I think the little rectangle ones should work inside one of the bupper cover openings. GOOD LUCK
