Topic: Bright lights (Read 1519 times) previous topic - next topic
Bright lights
I put my headlamp relay harness in today .
 The pics don't capture the difference very well , but it is a huge difference
Bright lights
What is different? Is the wattage output up from standard? Is that why you needed a relay?
Bright lights
Its a stand alone harness that allows the headlights to not run through the headlight switch.
The switch is used to turn on the relay and the lights run off the battery .
It does a couple of things , it puts 12v to the headlights making them brighter and it takes a huge load off the headlight switch thus extending it's life  :D
Bright lights
Quote from: hypostang;334974
Sounds like something I will need to do. I already suffer from the dreaded lights that dim at idle and brighten at higher revs.
Bright lights
Links? Write-ups? Anything useful?
Just curious because I need brighter lights!  :D
...and there was light!
Bright lights
I agree - I still believe it's like a 50% improvement over going through the headlight switch. If I remember right, it was something like 12v with the car running, at the headlight sockets, versus 14.5v with the relays. Voltage does not affect bulbs linearly.
I think the numbers at the Daniel Stern Lighting site, HERE, seems to show that this improvement is about right. This was one of the first things I ever did to the car, when I didn't know a thing about cars. It's still wired up today but sitting idle as a third harness (still have the stock one left alone and my active one for my D2R bulbs).
1988 Thunderbird Sport
Bright lights
Quote from: T-BirdX3;334976
See the link in my post above - it shows a wiring diagram. You can get a pre-made harness for 9004 bulbs in a variety of places but I have no links for that.
Bright lights
Yeah, that'll work as good as anything with such low wattage devices and short wire lengths. Personally I like something like 10 gauge wire for 5A runs but that's because I've become a perfectionist - there's no real reason to need the SAME voltage at the bulb as the output of the alternator, but I wanted it anyways ;)
Basically you just run one wire to the battery (or in our case, you can mount it on the battery terminal on the starter solenoid at the drivers side fender area), any wires to ground (there is normally one per bulb, and one per relay but the relays can share), plug the input into one of the existing bulb connectors on the car (as a signal/potential ground wire pair), and plug the bulbs in. A "plug and play" harness like this should take no more than 10 minutes to run the wires and wire up since you're looking at two or three screws/nuts to remove, place wire, reinstall, and plug into a couple connectors.
Bright lights
It took me longer to upload the pictures than it did to install the harness .
 This is actually the third car that I have used  a relay harness , I live in a rural area with no street lights and I like to be able to see.:D
