Topic: Getting door skins off? (Read 1986 times) previous topic - next topic
Alright, I've done this before on other cars but not this one. My 87 thunderbird has all the power options and all that fun stuff. I have the skin unhooked completely, but the midsection won't come off and I can't get the door handle linkage to unhinge at this current point. What am I doing wrong here?
88 Camaro RS - 355/TH350
87 Thunderbird Sport - 302 (351 going in)/AOD
Do you mean the door panel on the inside? You need to remove the one screw that holds the little triangle interior mirror cover (small black triangle shaped cover at the front of the window in the door)There is a screw at the lower front corner,a few plastic clips,a screw under each of the little rubber "plugs (square shaped) in the door pull,two screws in the door handle cups,and one screw that goes straight into the door behind the interior door handle.It also holds the arm rest to the door panel and door.
That is for the standard door panel.
The door skin would be located on the outside of the car, and you would also have to take the door handle off to remove it. ;)
Hellooooooooooooo.........................
Quote from: vinnietbird;334677
My post didn't go through for some reason.. anyways - yes I meant the plastic panel covering the insides of the door. I've got everything undone except for something hung in the center which I assume is the lock arm and I just haven't figured out how to unhinge it is my guess. + when you say BEHIND you mean that giant screw uptop near the glass? That's the only one I didn't take out yet, and I had assumed that was for something else.
Right behind the door handle,going straight through towards the center of the door is a long screw that holds the arm rest on,and the panel. There are only two screws at the "top" of the panel,and they are under little square "plugs" that are screw covers at each end of the door pull. Once they are removed,along with the others I mentioned in the above post, the door panel can be pulled towards the front of the car to clear the door handle,then off.Be sure to unplug the door lock harness from the door so you can set the panel out of the way.
The only screw near the glass that I can think of (and I JUST had my door panels off replacing my exterior door handles) is the one at the front,the mirror cover (interior0. Did you remove the door handle cups? That's the little plastic cover under the door handle inside.It has two small screws that go straight down,under the handle. Once they are removed,you can se the longer screw behind it that holds the center of the door in place.
Quote from: vinnietbird;334703
I'll look for it. if I can't find it I'll take a pic and maybe you can draw on it and repost it if I can't figure it out for some reason. I know this is simple and I'm just not seeing it/overlooking it.
Got it. I ended up getting both windows out, but it wasn't trouble free because I definitely skipped a step. How do you pull off the window seal trim? I'm assuming it clips on there real good somehow but I am not sure exactly how.
Does this help any?
http://www.foxtbirdcougarforums.com/showthread.php?t=20802
Quote from: daminc;334735
Does this help any?
I have these cookies next to me. I would give you one, but I have full intent on eating all of them. ;) Awesome find, thank you.
