Topic: HO conversion clarification questions (Read 3605 times) previous topic - next topic
OK, I have already upgraded my fuel pump and exhaust system and upper intake .
 I have a set  19LB injectors , a speed density HO ECM , a factory HO cam and a new timing chain .
I also have a timing gasket set  and intake manifold gasket set .
 I have 3 questions
  1. Do I "NEED" anything else?
 (I know E7 heads are in the list but I'm not swapping heads, if I were going to go through that much effort I would just swap the entire engine )
2. Has anyone done the conversion and kept the E6 heads?
 3. If yes to number 2 did you have decent results ?
 Back in 86 I had a brand new Mustang 5.0 LX coupe  and I seem to remember it having  enough pep to keep me happy for a while .
I'm assuming  what I am doing now will give me similar grins :D
The E-6 heads are by no means "great", but, I did the conversion as you are years ago and even with those heads (which I later swapped to porter E-7's) the car was a blast to drive and you could feel the power difference in the seat of the pants. Compared to the SO 5.0, it will make you happy, and you'll enjoy it until you make more mods.
Oh, as far as parts, you have what you need ( You need all of your gaskets, etc). It is a good time to swap on new water pump as well.
Thanks Vinnie . I thought I had everything ,just wanted to make sure
Good idea on the water pump :D
 It will be happening in  the next week .
Pics and updates.
the HO I put in my 79 cougar is awesome, makes the car move like never before.  I can only imagine what it would feel like in the lighter fox thunderbird.
What about exhaust? ;)
'Course, with E6 heads, exhaust really won't matter as much.
I already swapped to factory  mustang shortys and a cat-less H pipe
Heck, at this point, should you DO decide to swap heads, I wouldn't even piddle with E7's....GT40's or some such...:rollin:
I always keep my eyes open ;)
All this engine talk is making me drool! I don't by any means need a street racer but I want my car to eventually be a good running street cruiser...
Ok another question
I opened the box for my timing set and it is not a  double roller chain .
 It is just a standard run of the mill timing set ,
Do i need to go back to the parts store ?
No, but I would. I got a double roller for my s.o.
Quote from: Haystack;333326
Thanks , I will .  What was stock on the SO?
What you have was stock on the SO engines.The H.O engines had a double roller.That's all I will use. Costs a few extra dollars,but worth it.
