Topic: cam timing (Read 3636 times) previous topic - next topic
cam timing
was it just adjusted wrong?
Remember, if the women dont find you handsome, they should at least find you handy.
When all else fails, get a bigger hammer.
Chris
 93 cat rebuilt 3.8
cam timing
yep! im really looking forward to tinkering with my car tuning it up better bogusSVO.
it turns out the the cam was rotated a bit so put the cam pulley on 0 and rotated the cam until it lined up with the marker on the cover.
cam timing
today im going to play with the cam timing. its guttless down low but the higher the RPMs the more power i feel. so im going to advance the cam to 4 degrees.
cam timing
thats a good start, before you play with the time belt, you may want to try some more time advance (dizzy) I run some nutty advance 20* so you may want to bump that up by 2-4* at a time till you get pre/det/spark nock  then back it down about 4*
its a balance act betwen cam advance/ignition time and boost level get all 3 working right and you will be good
cam timing
alright, cam is at 4* tomorrow im going to try out 6. every 2* degrees seems to get me 1000 more rpm of power lower in the rpm range. at 2* Adv i felt power at 5500. at 4* i felt it at 4500. so if it keeps going 6 should get me power at 3500 hopefully. with the spout unplug its at 13* for ignition timing.
cam timing
once your happy with where the cam is, start bumping up your dizzy time...
