Topic: I Found My Next Project (Read 2353 times) previous topic - next topic
So, I was moving the 'underbird back in the driveway, so I can break out the washing stuff for it. Give it a bath, make it look good, all that stuff.
Well, I rolled ...well, pressed the button to make the window go down, because it was like a sauna in there. So I pressed the button for the window to go up & all I heard was the motor turning :rollin:
I reckon I need to take the door panel off and replace the window regulator stuff.
Rebuilding the regulator cannot be any worse than rebuilding the door hinge, so I'll get it done on a weekend after I get the parts in :headbang:
My pennies are on you need a set of Window Regulator Plugs
http://www.autozone.com/autozone/accessories/Automotive-Help-and-Miscellaneous-Products/Window-Regulator-Gear-Plug/_/N-25bw?filterByKeyWord=ford+window+regulator&fromString=search
My passenger window did that last year and I can tell my driver window is getting ready.
Good news is they are cheap.  Bad news is its kinda annoying to take apart/clean/re-assemble, but not hard.
Quote from: 88CougarGT;332134
Yep, the cam buttons are shot. The rebuild kit I ordered come with new cam buttons and a new nylon gear. Having not done this, before, I'm thinking it will be a two to three hour job.
Quote from: Scott D;332135
Not a hard job at all. Remove the door panel, unbolt the motor replace the nylon plugs and re-assemble. If no one has been in there before you might have to drill one hole in the door but there is a dimple in the door so you will see where to go. You will have it back together, washed, and all cleaned up well before the 2-3 hour mark.
At least you don't have to drill holes in the door to get to the bolts....
FOXLESS!!
1994 Lincoln Mark VIII
Alright!! The rebuild kit should be here, before the weekend :headbang:
Yup, I had to drill the doors on both my 86 and 92 Tbird.  There's only one bolt that's a bugger.  Simple job really.  Expect ses and cuts with a bit of blood if you are big handed.
Experience...:D
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
The rebuild kit was waiting for me, in the mailbox :headbang:
I should be able to get it done in a few hours, tomorrow. I'll post pics of the deal, in my post in the user rides section, of the process.
Do a write up with pics, and post it in the "how to" section. ;)
Quote from: daminc;332908
Or, I could do that, too :o
thats right . you need to be the guinea pig for the rest of us
w/MN12's. thanks for the writeups.--irv
Quote from: irv;332956
Not a problem, at all, sir.
I just got done with the power window rebuild. It took every bit of an hour. I did end up with one broken piece, but, it hasn't effected the functionality of anything. Plus, it gives me just one more thing to do with the restoration ;)
I should have a write up done, shortly. It'll be pic heavy and list all of the tools to use (on a 96/97, anyway).
Done with the write-up http://www.foxtbirdcougarforums.com/showthread.php?t=29213
