Topic: engine mounts (Read 7956 times) previous topic - next topic
engine mounts
if i was going to drop in a 5.0 HO into a 5.0 SO car, im sure the stock (liquid?) SO mounts will work without modification. from what i hear the stock stang ones wont work without modification. so i figured i should just buy some new SO mounts. that would be the easiest.
okay, assuming im right thats what ill do, but i have a few questions.
1, are the stock stang mounts so much better or worth moding for use?
2, would i notice a big enough differance with the use of solid or poly mounts?
3, anybody make em for our car or will they need to be moded too?
just looking for your  :2c:
~John~
Re: engine mounts
The Mustang mounts won't work period and the only way you can make them work is to swap the entire K-Member for one from a Mustang or pre '86 Thunderbird. I run solid rubber replacement mounts on my car and have no complaints. The hydraulic filled units are pr0ne to failure.
Re: engine mounts
huhmmm,
thanks man, :bowdown:
whered you get the solid rubber ones for our k member?
i can get the stang k member with the motor if i need it...would it be worth it or would i be opening a can of worms here? :dunno:
~John~
Re: engine mounts
If you have an entire donor car, you should be able to drop the engine, trans, and k-member as one piece and roll it around.
Re: engine mounts
is the stank k member or the mounts worth the trouble of doing that though?
~John~
Re: engine mounts
I'm not sure, but I believe all the  Tbird type aftermarket replacements are solid(cept probably the dealers). I've been using the Tbird mounts for 5 years no prob yet, and I have at least 275/300 drag strip passes on mine. They came from a local supplier(don't remember the brand), but most folkes say the NAPA ones are good.
If I ever get the 406 built, I will prob switch to the Mustang/early Bird K-member though.
Re: engine mounts
cool, how much were they?
~John~
Re: engine mounts
useing the mustang k member and mounts also free's up some room, and lowers the engine.
Re: engine mounts
I have the rubber mounts, and I seem to have alot of movement in the engine when I shift.  The trans is a manual.  I don't know if I tore one on a rough shift.  But ever since I put it together, with new solid mounts, I was unhappy with all the movement in the engine.  If you have the opportunity, swap to a Mustang K member.  It is going to be a real pain for me to do it now.
1988 Thunderbird
5.0 HO, t5, TC rear, TC brakes, etc. - Gone
Re: engine mounts
i checked all of the parts stores around here...nobodys got solid mounts for the V8 tbird...any tbird. they all only have the hydrolic ones....
~John~
Re: engine mounts
check Napa...........  napaonline.com lists solid and liquid filled
Re: engine mounts
cool...there they are the solid ones are actually cheeper. so these are actually better huh?
~John~
Re: engine mounts
John: Here http://www.mn12performance.com/mn12parts/em.htm are the ones I've got in my car the "EM100". They work fine.
Rick
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
Re: engine mounts
thanks i think im just going to go with the solid ones then...although ill have the mustang k member available...it doesnt realy seem worth swaping that sucka. the solid mounts seem to fit the bill. thanks again....john
~John~
Re: engine mounts
as I pulled the stock 302 out of my xr-7, both motor mounts were so shot they came apart into 2 pieces. The only sign I had that they were bad was I full throttled it one time from 30 mph to 70 mph and I tore a heater core hose off of the firewall. I put all new hoses on it and never had a problem with it, rode nice and smooth, no dents in the hood,etc.  I put the coincidence of two bad motor mounts and a broken hose together after I pulled the motor and saw the condition they were in.
I bought solid rubber ones from Napa, and also installing a polyurethane transmission mount to go with them.
