Topic: A237 roller cam 2.3turbo (Read 531 times) previous topic - next topic
the A237 and the biggest cam made by ford for the 2.3 turbo motor. its pretty choppy and people will know its not a stock cam in your car. it has .420 lift and 226º, 234º  duration.
here is a video of the cam (not me car) http://www.youtube.com/watch?v=iTH56NaaXmw
$275 the roller cam and HLAs. new cam alone cost around. $325
what else would need to be done to the engine and egine managment to run this cam?
John
It's a drop in cam. A quick search over on TurboTbird or TurboFord will tell you everything you'll want to know about it.
off the market for now. decided on building up a head so the A237 cam will stay until the head is built and put in
