Topic: 1993 thunderbird (Read 5997 times) previous topic - next topic
1993 thunderbird
i am thinking about getting a 1993 thunderbird and swapping engines, has any one swapped in a 351 4v Cleveland and C6 into a 93 thunderbird?
1993 thunderbird
I haven't, but if you consider the dimensions of a 4.6L fitting in one of these cars, then a 351C should.  I know they fit the '87 and earlier.
1987 TC
thanks for the reply
from 84 to 94 they only had the v6 from what i have read, after 94 they went to a v8, are the engine compartments the same?
 i was told that a fox mustang conversion kit may work and just wanted to see if anyone has done it. also d&d makes a kit for up to1986 fox thunderbirds, is there a lot of differance between the 86 and 93 in the engine bay?
1993 thunderbird
Where the motor mounts attach to the K-member changed mid-1986. It used to be the same as Fox Mustangs, but changed to their own design for whatever reason, lol.  Anywho, the Chuck W type 6 mounts are what I was referring to earlier that bolt a v8 to the redesigned K-member.  Chuck's on here, too.  Here's his page:  http://www.turbochuck.com/wp-content/motormounts.html  And as you may know, the 3.8, 5.0, 351W and 351C all use the same mounts.
1987 TC
thanks again.
thanks for the link, from what i understand the 3.8's even have the same trans bolt pattern as the sbf.
1993 thunderbird
Quote from: Dan Nelson;331659
Actually 1989 models only had the 3.8 V6 and the 3.8 supercharged V6.  1990 they had both the 3.8 and 5.0.  I'm not sure which year they switched to the 4.6 modular engine.  It's my understanding that the cross member is the same and all configurations.  It was called the MN-12 chassis.  Pretty much all metric but only the engine mounts differ.  Lots of transmission choices as well.  There is a tremendous amount of difference in the engine compartments.  The 89-97 Tbirds and Cougars have plenty of room for all the Ford small blocks including 4.6 and 5.4.
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
1993 thunderbird
thank you that helps out a lot.
1993 thunderbird
The 4.6 showed up in 93, and the crossmember changed, and thus the bases of the motor mounts changed, while the upper portions did not.
I'm not familiar with the stock motor mounts for a 351C, but I do have mounts that would mount a 302/351W into a 93-97 MN-12.
1993 thunderbird
the 351C uses the same mount as the 289,302,351W.
1993 thunderbird
one other thing i will have to research is the change over from fuel injection to carberated, how much computer stuff i need to remove and what will be effected from it.
this is the engine i plan to put in the bird.
http://www.youtube.com/watch?v=M_sp1MpupnU
1993 thunderbird
All fuel injected Fox Birds had the 5.0 as a option(Std on '87 & '88 Sport)... Only the 3.8 was available in '89 & '90, with the HO 5.0 added for '91-'93, first 4.6 were in the '94s... MN12 motor mounts for the '91-'93 5.0 will fit any small block including the Cleveland...
The '89-'97 T-Birds are totally different than the '88 earlier, virtually nothing will be a direct swap between the two...
1993 thunderbird
Sorry, I was thinking '93 on the 4.6 because the Mk8 (On the MN-12 chassis) appeared in '93 with the 4.6.
The TBirds/Cougars didn't get them until '94.
1993 thunderbird
Quote from: Chuck W;331724
Too bad the Birds & Cougs never had the 32 valve Intech version as a option...
1993 thunderbird
Quote from: turbocoupe50;331741
too bad the birds & cougs never had the 32 valve intech version as a option...
+1.
-'88 Tbird 3.8
-2012 Altima 2.5 BASE.
Future: Budget 5.0 300 HP.
1993 thunderbird
the 4.6 showed up in the 94s cause 93 was the last year of the 5.0 in the birds and cougars
Remember, if the women dont find you handsome, they should at least find you handy.
When all else fails, get a bigger hammer.
Chris
 93 cat rebuilt 3.8
