Topic: Gentex Rear View Mirrors (Read 5207 times) previous topic - next topic
I just purchased a Gentex Compass/Temp Auto Dim rearview mirror from Vinnie and installed it in my 08 Mustang. I thought it would be appropriate to post wiring diagram information for others so it would be at your fingertips if anyone ever needs the info.
There are two Gentex mirror plugs. Some are 7 pin and some are 16 pin. Wire colors may vary but pin positions are consistant.
Gentex 7 Pin Mirrors:
Gentex 16 Pin Mirrors:
Pin Functions
1-  Not used
2 - (Not used) Microphone (if the mirror is equipped with it)
3 - (Not used) "Passenger Air Bag on" notification (if mirror is equipped with that display)
4. -(Not used) "Passenger Air Bag off" notification (if mirror is equipped with that display)
5 - (Not used) If equipped with auto dim side view mirrors, supply line which goes to the LH outside rearview mirror.
6 - (Use) Temp probe connection (if mirror is equipped with display).
7 - (Use) Temp probe connection (if mirror is equipped with display)
8 - (Use) Ground
9 - (I did not use) Auto Dim Inhibitor while in Reverse (hook up to back-up lights)
10 -(Not used) Microphone (if mirror is equipped)
11- (Not used) If equipped, keypad signal (out) for On-star (pressing any button puts out a 5v multiplexed signal on this pin, You cannot use the buttons to        control whatever you want to.)
12 - (Not used) Onstar Equipped keypad supply (5v) voltage (in) for the buttons
13 - (Use) ignition voltage (12v -main power IN to the mirror)
14 - (Not used) Onstar equipped keypad green LED signal
15 - (Not used) Onstar equipped keypad red LED signal
16 - (Not used) If vehicle equipped with auto dim side mirrors, return line to the LH outside mirror for day/night signal.
If you have a mirror that is equipped with the temp display be sure to use a sensor designed for the mirror. It is a common GM style sensor but may be used on other makes as well. Do not use the temp sensor from any vehicle that has as roof console display such as the Ford Explorer. Those sensors are not calibrated for use with the Gentex mirrors.
Power, ground and sensor.  Looks pretty easy.
Which sensor wire is + or - ?
Mike
Quote from: mcb82gt;331578
Technically it has no polarity. I tried it both ways and it works just fine. None of the wiring info I have come across indicates any type of polarity.
I got my GM style temperature probe today and now it works perfectly. Love the mirror, especially the auto-dim feature. Secret to the temp probe is to mount it where it will not be affected by radiator and engine comparment heat while also not exposing it to too much cooling effect that air intake from the grille or any lower fascia openings create. I mounted mine inside the fender behind the front bumper cover and secured it to the turn signal lamp wiring harness.
Is the compass part self contained ?
I'm just curious,  I already have added an auto-dim mirror from a Lincoln so I don't know if I want to change  it, but any and all info is appreciated
Quote from: hypostang;331844
The compass is self contained and the calibration procedure is just like the one as described in the threads about the Explorer roof console.
This is such an easy install it's worth the change. All you need is 12V+ with the key on, a ground and two sensor wires. If you want to you can hook up the mirror dim inhibitor wire to the back-up light circuit when the vehicle is in reverse at night, but I did not hook mine up. You can easily pick up that back-up light wire within the wiring at the left kick panel where it goes to the back of the car.
I did not bother with it on my Mustang because the wiring runs on the right side of the car and is connected to these new fandangled Smart Junction Boxes.
I skipped the back-up light wire when I put mine in .
 I just ran the harness I grabbed out of a Town Car and  just used two wires .
I think I would like the compass but I'm still up in the air about the thermometer
Quote from: hypostang;332077
The thermometer is such an easy add that it was worth it for me. It just required a pair of wires run to behind the grille area then clip or tie the sensor in place
Quote from: Watchdevil;332083
Do you know if the sensor from a town car would work ?
It had a thermometer in the dash . I have one of those sensors .
Quote from: hypostang;332086
I tired to use the sensor from an Explorer with the roof console and it did not work because it is not calibrated for Gentex mirrors. I would suggest sticking to a sensor that is used with cars factory equipped with Gentex mirrors with temp readout. I had to get a sensor that was compatible. You can find them used mostly in luxury GM cars, trucks and SUV's. Search ebay for GENTEX TEMPERATURE SENSOR and you can find them new and used.
I got one from this eBay Seller:
http://cgi.ebay.com/ebaymotors/98-99-GMC-Chevy-Gentex-Mirror-Temp-Sensor-_W0QQcmdZViewItemQQitemZ150480898493QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
More listings:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=gentex+temp+sensor&_sacat=See-All-Categories
