Topic: Battery is discharging (Read 1333 times) previous topic - next topic
This is my 88TC.  If I dont drive it everyday, the battery drains.  The battery is good, and I just had the alternator tested and the voltage regulator is bad.  Will the diodes in there cause the battery to discharge?
Yes, they will.
cool thanks...this was driving me nuts.
yes for sure, very common problem on the earlier models with external regulators. I have a couple used alts for 87-88 TC if you need one.
John
Thanks hcor, but needed to get one ASAP as it's my DD.
No problem.
John
Quote from: hcor;331370
even for internal regulators.
i started my paracitic draw testing right at the solenoid, found out with my bulb that the alt feed was still lighting up the bulb with no key in.
this was on a EECIV / TFI FI 1990 ford bronco 351w with 5speed.
