Topic: Rear End/Speedometer Gear Question (Read 1631 times) previous topic - next topic
I'm sure this question has been asked, but a search didn't show me what I was looking for.
When I swapped in my 87 thunderbird engine and AOD tranny from the car, I left the stock rear end. It is a one leg, 3.08 rear end, which came mated to the 1988 thunderbird 3.8lv6.
I have a vss signal error message when I run codes, and I'm guessing I have the wrong speedometer gear, so either vss thinks the car is going faster or slower. Having a 3.08 rear as opposed to the 2.73 limited slip rear the v8 came with, I would assume the speedometer would read higher than my actual speed, correct? What gear would I need to put in the tranny to make it accurate for the 3.08 rear? Is it hard to change a speedo gear? Are they expensive?
Scroll down past the ring and pinion sets and there should be a chart that will be helpful for you. :D
Chart
this might also help if you have done gear and tire size change
http://www.accuautoparts.com/calculatorfin.jsp
if needed i have a set of 2 speedo gears im not using i could sell ya on the cheap. bought em for my 84 that had the v8 with the 3.08 rear end.
Got that fox rash again!
-Resident smartass! :ies:
Quote from: ThunderbirdSport302;331277
Chart
I have the automatic...?
the far right part of the chart is for autos...... with you having the 87 AOD,
depends on what drive gear you have in your auto trans,  a 7 tooth or 8 tooth
but from what it looks like to me.....
if you have the 7t drive gear you need the 18T Gray C7SZ-B <-- that is an obsole number
chances are this would be more of your set up
8t drive gear and you would need the 20T Orange C8SZ-B
If it's a T-bird/Cougar AOD then you have the 8 tooth drive gear.
I answered in the misc tech as well but for everyone, THE SPEED SENSOR COULD CARE LESS WHICH REAR END OR WHAT GEAR IS IN THE TRANSMISSION....
NOW since you have a '87, there is no wiring connection to the EEC from the speed sensor... Of course this assumes you've swapped a '87 harness...
I was wondering why the hell a different gear ratio would throw a code?  I always learn something new though. LOL
Mike
