Topic: o2 extension harness, help finding (Read 2524 times) previous topic - next topic
Well was going along the make my own wires for the sensor route, BUT there is absolutly no slack behind the engine to work with. Went to both our local junkyards and they want close to 120 for a o2 wires from a mustang. F that...
Went to advance auto parts downtown, and they dont offer anything.
Anyways, last week I found a set on summitracing.com that I could use for extensions. But now I do the search and can't find it. Just my luck.
Anyone have any part numbers or know of anywhere else I could possibly get these extension harnesses for the o2 sensor. Any size from 12-36 I can adjust when neccessary, I just need to plug in behind the engine to get some more slack down the line, so if its not a direct fit then I'll add some extra wire.
btw
its a 5.0l
factory mustang headers
bbk h-pipe
if that helps at all.
THanks for all your help
Appriciate it all
-Steve  :bowdown:
Re: o2 extension harness, help finding
thanks bud appriciate it. Will order when I get home from school
No problem ;)
No problem ;)
good price on 50resto
wow, even better.
Thanks guys got some good sites to check out for future deals.
Any other sites for price cost comparision?
I really need to expand from ebay only and every so often, summit.
There is alot out there, just haven't found it yet.
becarful 50resto takes about a century to maile something out to you. my cobra shifter  and speedo gear took about a month to 3weeks each
Hey nate what do you use on your long tubes? I thought there was an o2 sensor with a longer pigtail that people that have LT's always get.
Just finished putting on LSC shorties, H-pipe, etc. I made my own extension wires by cutting off the female plugs (cutting harness wire as deep as I could reach off a pick n pull car), and the male plugs by cutting wires at same car O2 sensors. Getting more o2 sensor wire off another car. Then soldering together wires while first fitting on shrink tubes and reflective fabric insulator tube(3/4" dia.) on the wires. This resulted in nice patch assemblies that measured approx. 18" ea. Plugs and wires real cheap, but sewn insulator tube stock was a little pricey for 3' length at local performance store. But did I say it looked nice!
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
i made my own bob, i used the ends from my car and a parts car and soddered em together then put heat shrink over em. dont use but splices tho because the extra resistance can throw off the sensors readings sence their so sensitive.
ah I fouind it..  The Bosch 02 sensor #13953 from Autozone comes with the 16.5" wires :)
edit** ok got more info..
Bosch 13942 8 1/2-inch harness $38.99
Bosch 13953 16 1/2-inch harness $44.99
Bosch 13950 13-inch harness $39.99
Quote from: thunder306
Exactly what I bought, for my "future" upgrades!
