Topic: torque converter ?s (Read 1191 times) previous topic - next topic
torque converter ?s
in my 84 bird 5.0 do i have a locking or non locking converter?
someone gave me a 2800 stall lentech non locking converter and i am wondering if it is compatable
i am running a stock bore forged bottom end,tfs stage 2 cam p&p gt40p heads ,dual plane air gap intake and a vac sec 650 carb
thanks for the info
mike
1996 tbird 4.6 auto--STOCK BOTTOM END WITH OVER 183K MILES
12.82@105.3MPH on the juice
13.82 @98.59 all motor
1991 COUGAR LS 5.0 AUTO
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 gt40  12.33@110.04
1989 mustang gt 10.68@126.97
1984 tbird 5.0
torque converter ?s
You should contact Lentech but assuming you have a std lockup AOD, no it will not work, will require the input shaft be changed to a one piece type... There are non-lockup converters that can be used but those are designed to use the std AOD dual input shaft..
torque converter ?s
I have a PI Stallion non-lock up 2800 stall converter and it needed a one piece input shaft. IIRC the Lentech converts are similar and require a one piece input shaft.
torque converter ?s
so i wud just need to get a hardend one piece input shaft?
the part number for the converter is 24035
mike
1990 ford f150 5.0
1984 tbird 5.0
torque converter ?s
Yep. You have to take the trans apart to put it in though.
