Topic: cooling system question (Read 983 times) previous topic - next topic
what would cause the coolant recovery not to work? the hose is fine no clogs or holes the port to the filler neck is clear. the coolant pushes out of the rad cap when the car cools down. the odd thing is if you take the rad cap off when the car has cooled down it is pressurized.
eddie
my rides well some of them work:hick:
1995 towncar in black 246 K non running
1989 continental 110K waiting for a part
1984 cougar head gaskets done almost ready!
Yikes the daily ride ...1998 chevy lumina:hick:
Quote from: blackcat85;329689
Eddie,
Unless the engine is cold pressurized is a good thing.  You have no leaks.  The coolant overflow tank is working if it's not overflowing.  I'll bet if you check it when it's been sitting for quite some time you'll find it's not pressurized.  The coolant flows out of the radiator when hot and sucks back in when cooling down.
No Defect.
Steve
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
yep. Just like tbirdsps said. If you leave it overnite then the pressure may be gone. But you want the pressure so you can get the engine up to the 185 + degree heat without boiling over.
:burnout:
well the pressure got even worse... the overflow hose kept popping off the rad neck. so i took it off the overflow bottle and was checking the inlet/outlet on that. i dont know what was in there but that hole was clogged. everything working good now!
eddie
