Topic: tripminder (Read 3143 times) previous topic - next topic
tripminder
OK, I've  searched and searched; thought I'd seen it before but can't find it. I got a tripminder from a Grand Marquis. I wired it outside of the car for testing and none of the buttons work when you press them. Saw a post from TC to clean the contacts inside with emory cloth. I opened it up and found simply bimetal switches that pushed down for contact. Emory cloth on the top of these surfaces wouldn't do anything that I can see; I would need to separate the contacts to clean them in between, yes? Is this what I was supposed to do? Not sure if I can separate the contacts. Anyone have input?
tripminder
http://foxtbirdcougarforums.com/showthread.php?t=2638&highlight=tripminder+install
and there is also a good writeup on coolcats...
http://www.coolcats.net/tech/advanced/tripminder.html
tripminder
There it is , thanks 88. Forgot to check the cool cats website. Time to take it apart again!
tripminder
Cool Cats is a wealth of info that seems to get overlooked or undiscovered until one of us directs someone to it.  There are a lot of things that I would have been lost trying to do without the site.
tripminder
Got the brackets changed over and wired to original digital clock harness. Lucky me, the LS had all of the wiring to the original clock jumper. Added two wires for vss and fuel flow; trip works fine but I'm not showing any fuel used. Ohmed wire to pcm and have continuity to pin 34. Now I only drove a half mile, but should I expect to see fuel usage on such a short trip or should I wait until I get a chance to drive it some more?
tripminder
Does fuel flow need any other pcm inputs or how is it calculated? I don't really use much of the EEC system.
tripminder
you might not have the right wire. are you showing instant mpg?  I think the wire I tapped was light blue pink stripe but I cant remember right off hand
tripminder
Oh yes, I have instant MPG. Way more than actual - I expect the number to be  < or closer to 10MPG. shows I think over 60MPG right now
tripminder
sounds like you dont have the right wire for fuel flow making it read higher than normal.
try this for location
tripminder
Nope. Got it pinned to 34. Less than 1 ohm resistance from pcm to tripminder terminal. Maybe it just needs some more driving time?
tripminder
I may be missing inputs that the pcm is looking for. I didn't mention it but the car is originally a 3.8L with that harness installed still. It now has a 5.0L that is carburated but running the stock in-tank fuel pump. The pcm is used primarily to turn the pump on and off with key input, I can't think of any other functions being used right now.
tripminder
Yes, but I suspect that I don't have enough input the pcm for it to figure out the fuel useage. I found a test in the shop manual for the tripminder functions that I will try when I get a little bit more time. Or maybe I've got a bad pcm, that could be a possibility. Wish I saved the 5.0 one to try it.
tripminder
OK. Finally ran through the fuel flow test and I feel convinced that I will probably need a fuel flow sensor to make that portion work. Does anyone know if somebody still sells them aftermarket or from Ford? How about the pigtail? Any leads would be welcome.
