Topic: another problem : ) (Read 977 times) previous topic - next topic
another problem : )
so today i was looking over my motor and i noticed one of the fuel connectors wires were cracked open so i could see the copper wiring and the connection looks like it has been melted. I put some electrical tape around each of the wires for now. Does anybody know if i could buy the connection with a pigtail anywere? or do i have to get a whole new harness...
another problem : )
yes that would be great! i need about 1.5 inch of wires of the plug. i'll send you a pm
another problem : )
You can but most if not all of those pigtail for your entire car at your local parts store. If they tell you they can't they just don't want to sell you anything. Also if you go to borg warner's site they normally list the part number of the pigtail with the part.
another problem : )
Just go to the junk yard and cut the pig tail off of another Ford that has the same one you need. It's a cheaper option;)
another problem : )
Quote from: ipsd;327056
Borg Warner is Standard now, some part #'s are the same most aren't.
another problem : )
napa carries the fuel injector pigtail for "bosch style " injectors.. about 5 bux each
